doesn an 89 ecm work with 86?
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
does an 89 ecm work with 86?
i have a tpi system from an 86 t/a but i have an ecm from an 89, can i use the 89 ecm with the 86 system? i've been told that '86 used a cold start injector but '89 didn't. what's the difference and what problems am i going to run into?
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
i believe you can. im pretty sure the 86-89 ecms are interchangeable. you are correct about the cold start injector but that is in the prom not the computer. you should be alright as long as you change the chip. the chip you have to use is 86-88.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
what will i do to block off the hole from the cold start injector?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Originally Posted by Street Lethal
You can do that, or simply keep the 89' prom, and toss you're cold start injector entirely (it'll help to unclutter the engine bay)...
The computer is the same, just the prom is different as Green89IROC said.
Originally Posted by Kevin91Z
You cant use the stock '89 PROM, as it has VATS and the '86 does not
Originally Posted by Ughh61
you could use a blockoff plate to keep it clean
or just leave injecter there
id go for the blockoff plate and keap the cleaner look
Originally Posted by johnnyboy
the tpi system is from an 86 ta but it's going into an 89 formula which also has vats, so will it work?
Edit: Whoa, wait a second, just glanced at you're sig. Are you trying to mate an 86' TPI unit with an 89' TBI ECM? Or do you have either an 86' or 89' TPI ECM? Lay everything down on the table for us, whaddya got?
Last edited by Street Lethal; Jun 25, 2006 at 07:35 PM. Reason: Automerged Doublepost
Then I misunderstood the original post, as I thought he was trying to mate an 86' TPI system (intake, plenum, runners, throttle body...), with an 89' ECM and harness.
That's what I originally thought. Yes, it'll work just fine. Just get yourself a cold start injector "removal" kit, try Summit Racing
i hope there's no more confusion anymore lol
i have a 1989 formula with the tbi 305, i bought a tpi setup off an '86 T/A in a jy but minus the computer and i now have a tpi ecm from an '89 tpi system. so i am putting together an '86 tpi system(wiring harness intake runners and all minus the ecm) with an '89 tpi ecm to replace my tbi setup.
i'm planning on getting a set of tpi heads, i have the maf and the complete wiring harness
