underdrive pulleys.. worth it?
Old Jun 25, 2006 | 12:51 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
just wondering on your guys opinions. I'm considering buying a three pulley set - underdrive for the crank, waterpump, and alternator.
let me know what you think.. worth it, hype, or very little gains?
Old Jun 25, 2006 | 01:05 AM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
just get the crank pulley. ive got one and noticed a small gain in throdle responce.
Old Jun 25, 2006 | 04:15 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
They do work and are worth noticable horsepower. However, on a street car you will notice your headlights will dim while you're stopped at a light. If you also have other acessories running like a huge stereo it could use more power than your alternator can provide. Then your battery will die soon after.
Old Jun 25, 2006 | 04:39 PM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
MARCH do a set of pulleys called Power and Amp, it's supposed to drain less power... I may try them myself soon.
Old Jun 25, 2006 | 06:11 PM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
i have the march 2 piece set on my l98 (power and amp) and the motor was stock at the time of the install and noticed a gain throughout the power band almost instantly. not to mention it dropped my times and little over a tenth consistantly. Do it!
Old Jun 25, 2006 | 06:19 PM
Brisk's Avatar
interesting.. power and amp set..
how about a waterpump pulley.. anyone notice higher temps or anything like that?
Old Jun 25, 2006 | 06:25 PM
Grant88irocz's Avatar
Car: 88 Irocz
I put on the same kit on my car. The only down fall is some times my lights dim down at idle, but worth it in the long run!
Old Jun 25, 2006 | 06:58 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Even the power and amp series should make the lights dim a little, but should be less than the other kit... The Power and Amp kit is supposed to give about 11HP and the normal 12.5HP...
bigjay89gta
Oct 15, 2015 08:04 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
