What are these lines??
Old Jun 25, 2006 | 06:20 PM
airbrushguy's Avatar
I picked up an '89 350 TPI Formula gas tank for a hotrod I'm building. I'd like to use the tank since the engine I'm using is a TPI. However, I didn't remove the tank and so I don't know where the FOUR lines that come off it go to. Could somebody straighten me out as to what lines do what?
Old Jun 25, 2006 | 07:40 PM
Ughh61's Avatar
http://www.alldatapro.com/alldata/PR...09088/59043292
that all i can find right now
ill keep looking
http://www.alldatapro.com/alldata/PR...09080/14471155
Old Jun 26, 2006 | 09:32 AM
Thanks Ughh61, but the link is dead as far as I can see.
Old Jun 26, 2006 | 07:11 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
one is the fuel tank vent, one is the supply line, one is the return line, and one is the vent to the charcoal canister.
Old Jun 26, 2006 | 10:21 PM
Do I need a line to a charcoal canister? And where does the fuel tank vent line go to? All I have is about 12" of lines after the edge of the tank.
Old Jun 26, 2006 | 10:33 PM
Elephantismo's Avatar
Car: 91 z-28
Engine: 350 F code
Transmission: 5spd
the charcoal canister is for emmisions and saftey purposes. The motor actually pulls vacuum on the charcoal canister i believe. The vent also goes to a small charcoal container that is mounted close to the tank. Both are to prevent the tank from bursting under pressure. The small charcoal container is all that is necessary for saftey i believe. The vacuum assisted canister is necessary for emmisions.
Old Jun 27, 2006 | 10:08 AM
Are the small containers still available from Chevy?
Old Jun 27, 2006 | 11:26 AM
87zjeff's Avatar
the small one you refer to is just a diaphram type check valve. i don't know if the dealer still carries them or not. you can use just the small one but it will not keep the pressure off the tank. it takes some pressure to relieve it where as the charcoal canister is the primary vent that requires very little pressure.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
romcjr
Sep 17, 2015 05:18 PM
TBRays98
Sep 6, 2015 05:05 PM
