help with code 33
Old Jun 26, 2006 | 05:03 PM
cammed91's Avatar
Car: 1991 Pontiac Trans Am
Engine: 350 HSR, Cam, ignition, headers
help with code 33
alright i have a 350 with TPI, cam, exhaust, ignition, HSR, 180 thermo, free mods. well it has been down now for about a month mostly because i have been out of town but i need to get it running well and today i went to go and work on it and still had to lash the vavles, so i did. after that it would idle pretty good but if i gave it any gas it would almost die and if i let off it would idle fine again. it kinda sounded like it was backfiring if i listened to the throttle body. it had a code then and i pulled it, it was 33 high voltage/ low vaccum at the MAF/ or MAP in my case. i checked the vaccum line and it was not blocked or anything. anyone had this problem, or could help me out at all. any help would be appriciated. Thanks
Old Jun 27, 2006 | 11:15 AM
Vader's Avatar
Connect a vacuum gauge to read manifold vacuum durign idle. Check the MAP voltage and compare to the chart:
Old Jun 28, 2006 | 10:11 PM
cammed91's Avatar
thanks i was feeling pretty lazy so i just went and bought a new one.
Old Jun 29, 2006 | 06:29 AM
Vader's Avatar
So, how did that work for you? Solve the issues?
Old Jun 29, 2006 | 11:16 AM
cammed91's Avatar
yea it runs ok now except for it was a little hard to start and i solved that by lowering the advance to about 8 degrees. it was at like 15-18 initial i don't know how it was that far but i moved it back down and tightened the bolt down real tight. i am still getting it not idleing very well. it also smells kinda like the exhaust is a little rich too. it smokes sometimes a kinda black smoke and it smells a lot like gas. not quite sure what is wrong, i wouldn't really think it would run rich seeing that they are stock injectors on a HSR with a cam, full ignition, 50 PSI fuel pressure, and full exhaust, but maybe something in the computer is screwed up. i know that i really need a tune but i haven't been able to get into ed wright yet so for now it is just the stock tune. any ideas would be nice, if i could fix it would be nice.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
