quick and painless timing question
Old Jul 3, 2006 | 02:48 AM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
alright, i just wanted to get this straight.... i have a 1989 firebird formula 350 TPI...... how exactly are you supposed to set the timing on this car? the chilton manual says to ground the A and B terminals before setting the timing. if i do NOT ground these terminals, the timing changes as the rpm's of the car changes. am i supposed to disconnect the EST wire to set the timing?? i tried it, and i got a check engine light, and the engine sounded like it was running rough, but i reved the engine and the timing light stayed steady at whatever it was set at. please let me know the CORRECT way to do this, thanks!
Old Jul 3, 2006 | 08:40 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Pull the EST wire and set the timing :-)
Painless enough?
Reset the ecm(disconnect power) after u set the timing cause u will set the EST code.
later
Jeremy
Old Jul 3, 2006 | 01:21 PM
bigchief's Avatar
awesome, thanks. you ever hear about that a&b terminal way to set it?
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
squiggy2
Aug 9, 2015 09:30 PM
