MAF sensor issues
Old Jul 9, 2006 | 10:06 AM
brew_crew_011's Avatar
Car: 1988 Camaro
Engine: chevy 350
MAF sensor issues
I have a 1986 Iroc TPI 305. Its been to a shop and $700 later, its still screwed up. The codes 33 and 34 are popping up, and the cars not running right. The Maf sensor has been replaced 3 times, and the computer twice. If you guys have any clue, it would be extremely appriciated. Thanks
Old Jul 9, 2006 | 01:34 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
did you check/replace the burn off and power relays for the mass air sensor?
i would check/replace those first as they are the most likely culprit.
next i would check the tps voltage.
how exactly is the car not running right?
Old Jul 9, 2006 | 02:04 PM
don't be a leg's Avatar
try replacing the maf relay.
Old Jul 9, 2006 | 11:18 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
If they have both been replaced multiple times, it would suggest the problem is not there.
Have you physically checked the wiring out with an ohm/voltmeter?
Have you physically tested the relays and associated wiring?
later
Jeremy
777Shock777
Oct 29, 2015 04:30 PM
Logan Bryant
Aug 27, 2015 11:52 AM
Bert87
Aug 23, 2015 03:50 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
