need some info about my ecm
Old Jul 9, 2006 | 03:03 PM
alabama_lowlife's Avatar
Car: nissan titan and nissan hardbody
Engine: 305 tpi
Transmission: manual
i'm very new to the tpi world so i'm just trying to get a handle on what exactly i have so i can figure out what info is applicable to me. i looked on my ecm and there are 2 number2 on the paper label. one says "service number 01222165" the other is 12271s5310. does one of those represent the "style" of ecm i have? i believe the motor is from an 86 camaro. it's a 305. neither of these numbers had any results when searching.
also, is setting the minimum air and the tps something i need to do? i read that tech article, but i don't know what the ALDL is. like i said i'm still in the early stages of the learning curve.
thanks for any info that anybody can offer.
Old Jul 9, 2006 | 11:14 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Its a 165 ecm.
The other number is prolly a service number from the dealer or aftermarket piece that was replaced.
The ALDL is somewhere near your feet. Its a little black connector with 12 pins in it.
Should be towards the driver door on the underscuttle above where your feet go on the drivers side, Might have to pull off the fuse box cover to access it.
Or its on the dash with a blanking panel over it for access. I forget where it is on what years,
later
Jeremy
Elephantismo
Feb 13, 2019 12:51 AM
skeltor
Feb 2, 2016 10:37 AM
customblackbird
Oct 1, 2015 04:30 PM
F-body-fan
Sep 24, 2015 08:29 AM
Billy Decker
Sep 4, 2015 03:46 PM
