Bigmouth base
Old Jul 10, 2006 | 08:24 AM
cutnsick's Avatar
Car: 88 GTA Pontiac right hand drive
Engine: 350 CI
Bigmouth base
Just rebilding engine with comp 270 cam ported vette heads 11:1 CR etc....
Will an aftermarket base make much difference? The sootout seens to suggest the big mouth is the best.... I already have runners. Any opinions?
Old Jul 10, 2006 | 08:37 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Base should help you breathe a lot easier, and a little higher in the RPM band. I want to port my stock one and see how it does. Might eventually go with a larger base myself. What runners are you using?
Old Jul 10, 2006 | 11:10 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Buy and edelbrock base and port it.
Will save u money over the bigmouth and thats all it is anyways.
later
Jeremy
Old Jul 12, 2006 | 06:53 AM
cutnsick's Avatar
Engine: 350 CI
I have eldelbrock runners ive semi ported the original but thought the bigger one might better suit the heads. is there really much price difference?
Pac J
May 17, 2020 10:44 AM
db057
Jan 10, 2020 08:55 PM
bjpotter
Oct 4, 2015 07:48 PM
ndndndnd
Sep 28, 2015 08:00 AM
