New Injectors or Clean Current Ones?
Old Jul 12, 2006 | 09:30 PM
master486's Avatar
Car: 87 Camaro IROC-Z
Engine: 5.0 LB9 Stock
Axle/Gears: Stock BW 3.45
Hi everyone,
Just want to get some opinions on what I should do. Should I get my original injectors cleaned with Cruzin Performance or should I buy the 19# Ford SVO Injectors from Summit. Do brand new SVO injectors offer any advantages over perfectly clean/flowing OEM injectors? Thanks in advance.
--Chris
Old Jul 12, 2006 | 10:39 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
IMO not worth it. Have them cleaned and flowmatched.
Old Aug 3, 2006 | 11:24 AM
formul8!!'s Avatar
Car: 2004 GTO
For what cleaning costs vs buying new ones? Take in consideration time for R&R, gaskets, etc.
Buy the new ones.
Old Aug 3, 2006 | 12:23 PM
Vader's Avatar
Your '87 original injectors should have been the RP/Bosch type. Those are certainly worth cleaning if the coils are intact. But don't take MY word for it. Send an email to Rich at Cruzin Performance and get his expert opinion. You might also ask about the current backlog and schedule. The last I knew, he was busier than a potato chip vendor at a pot-smokers' convention.
The other consideration is that the new set may not be matched very well either, but you can ask Rich about his experience with that, too. I've been fully satisfied with the service there, but that's just me.
Old Aug 3, 2006 | 04:33 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Your not the only one Vader.I've had a set of 19 & 22# injectors sent to Rich with no problems.
Old Aug 3, 2006 | 06:43 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Axle/Gears: 9 bolt 3.70s
Well, I think you should Ohm them and if they check out OK, then send them to rich.
He did my injectors also, great service.
Old Aug 7, 2006 | 07:44 PM
master486's Avatar
Ok so if testing after the engine is warm, what is an acceptable range of resistance? What is too low/high and what is the maximum % they should all differ by? If one or more is too out of range, is it junk or can it be rebuilt?
Thanks,
--Chris
Old Aug 8, 2006 | 08:38 AM
Vader's Avatar
Anything below 12 ohms HOT is a potential problem for the Rochester/Bosch injectors.
Old Aug 8, 2006 | 09:40 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Thanks,
--Chris
What I did was have Rich clean and flomatch both of my sets of injectors.Any that are not within 2% of each other he keeps and replaces them with one's that he has that are within the others
Old Aug 10, 2006 | 03:08 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I had mine cleaned and flowmatched . Definately a good move. They even showed me how good they were before and after. This was at KWfuelinjection.
Old Aug 10, 2006 | 08:35 PM
master486's Avatar
Thanks to all that have given their input. I'll test the injectors when I return to CA next month. I'll post if I find anything unusual when I test them. Thanks again.
--Chris
specialized
Jun 18, 2022 09:26 AM
69 Six Pack
Oct 5, 2015 07:51 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
