Where should I begin with my Z
Old Jul 13, 2006 | 08:19 AM
JSZ28's Avatar
Where should I start with my Z28. I am new to the TPI stuff so I need some help. My car is a 91 Z28 with a 350 auto. It already has K&N filters, flowmasters and maybe 3:73s. I would really like to wake this car up without a blower or nitrous. I want to build a good street/strip car. Any suggestions?
Old Jul 13, 2006 | 10:03 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
headers, (get rid of the smog pump and all the lines) Aftermarket intake and runners swap, adjustable fuel pressure regulator, new roller cam, port the heads, new ignition system, the list is endless, Have a custom chip made after your all done.
Old Jul 18, 2006 | 12:37 PM
JSZ28's Avatar
What's the most bang for the buck mod?
Old Jul 18, 2006 | 12:45 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
that is a controversial subject...since it's an auto, a stall would be an awesome thing to have. 3.27's are about the steepest a TPI car needs...TPI runs out of breathe after 5,300-ish. Another thing to get is a HSR (holley stealth ram). amazing mod for your TPI car. Comp Cams and Crane Cams make some nice products for our cars also.
Old Jul 18, 2006 | 01:43 PM
Demon355's Avatar
Why tell him to get TPI gears then tell him to get an HSR? lol...
Exhaust and Intake parts are the first place to start. Wake the car up alot.
Old Jul 18, 2006 | 01:58 PM
BlueZee28's Avatar
i should had worded it better...he is asking what's the first thing to do, either an HSR OR a stall...if you get the HSR then get new gears and then a stall...if not, then get the stall and dont worry about gears
Old Jul 18, 2006 | 02:09 PM
Nitsuj86Iroc's Avatar
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
best bang for the buck would be a throttle body bypass - couple of $ for a hose, and porting the plenum right behind the throttle body - probably free. there are good tutorials. Iv done that and now Im onto exhaust, i put in hooker 2055 headers and y-pipe and i will be putting on a cat and cat-back soon.
if u really plan to get into it, any prom tuner will tell u to learn to burn your own chips, that way, any mod you buy can have the proper tuning to adapt to it so that you will get the most out of them. something like swapping the TPI for a HSR would definitly benefit from a new prom.
ZZ3Astro
Aug 13, 2019 12:57 AM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
starliner
Feb 9, 2016 08:18 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Marc Brown
Sep 28, 2015 01:40 PM
