ZZ9 or XFI 268 cam?
Old Jul 13, 2006 | 03:31 PM
HD4mula's Avatar
ZZ9 or XFI 268 cam?
This will go on a 350 TPI with AFR 180s, 1.6 RR, ported Edelbrock base, AS&M runners, ported plenum (Corvette Plenums) and 52mm TB. Tune will be custom of course. I heard good things and HP/TQ numbers from both of these cams. Car will be a semi daily driver. I will not ditch LTR as I can sacrifice some HP over TQ and I like the look of LTR. It is a stick shift application. Which do you think will perform better? By how much? Tks
XFI 268 specs
Operating Range: 1800-5800 RPM
Duration Advertised: 268° Intake / 276° Exhaust
Duration @ .050'' Lift: 218° Intake / 224° Exhaust
Valve Lift w/1.6 Rockers: .570'' Intake / .565'' Exhaust
Lobe Separation Angle: 113°
ZZ-9 HydraulicRoller:
Intake Exhaust
Advertised Duration 282 287
Duration at .050 212 226
Gross Lift .483 .520
Lobe Separation 112
Old Jul 13, 2006 | 03:45 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
IMO I think the XFI might be too radical for a daily driver.
Old Jul 13, 2006 | 10:24 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
The ZZ9 cam has done well in my car. Managed to get 330RWHP with one. Idles nicely almost like stock. However I feel I'm at the limits of the cam. My current build up will have the 218XFI cam in it. By the way the 218XFI has an advertised duration of 268 degrees and the ZZ9 has an advertised duration of 282 degrees on the intake side. I believe the 268XFI will idle just fine.
Old Jul 14, 2006 | 10:20 PM
HD4mula's Avatar
1989GTATransAm; Are the 330hp with the Trickflow heads?
I think I have seen someone else (Madmax?) here who also did 330+hp with the XFI cam. That would be perfect for me (300-330rwhp). But why similar numbers with such a difference in lift between the two? If I go with the XFI I will need to upgrade the springs. Now I feel more inclined to the ZZ9 because I can run it with the stock AFR heads srpings. Any comments?
Old Jul 14, 2006 | 10:59 PM
Car: 1989 GTA
Engine: 369 TPI
Madmax and myself have virtually identical power numbers including torque. The main difference is that he is using stock TPI runners and a bigger cam and I'm using SLP siamesed runners with a much smaller cam. By the way we were on the same dyno on the same day.
Yes the 330rwhp is for out of the box Trick Flow heads with the dual springs. The dual spring version will handle the higher lift and is good up to .600 lift. Madmax is running the 230XFI cam and AFR heads.
Old Jul 14, 2006 | 11:23 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I too, have the ZZ9 cam w/E-tec 200 heads making 324RWHP & 405RWTQ
I am using a similar intake setup like [1989GTATransAm]
also on the same dyno
(see sig) under avatar.
Old Jul 15, 2006 | 12:00 PM
25thz383's Avatar
Car: 92 Z-28
Engine: 383
zz-9
I am running the zz-409 with fast burn heads on a 383 and love it. Idles fine, just a little lopey but performes great mid to upper range.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
