Idles fast, then slowly drops to normal...
Old Jul 16, 2006 | 09:35 PM
LT4Hawk9's Avatar
Car: 1997 LT4 Firehawk
Engine: 350ci LT4
Transmission: MN6 6 Speed
Axle/Gears: 3.42:1
I've got an '87 Trans Am with a 305 TPI and 700R4.
When I first start it, in park it idles at 1200-1500 rpm for a minute or so, then very slowly drops to 500-600 rpm. If, during this time, I touch the throttle at all, it settles back in high, and slowly begins the drop again. Drive the car, and come to a stoplight, and it idles fast, slowly dropping as I sit at the light. Even after an hour of driving, the same story...so it doesn't go away after operating temperature is reached.
I just recently bought the car, and finally started driving it yesterday, and the only thing I've really done to try to remedy this issue is set the TPS. It didn't change a thing. AFAIK, the only mod that may be relative to anything is a Hypertech chip.
So, my question is...Now what?
Thanks for any help you guys can give!
Old Jul 16, 2006 | 10:47 PM
toddztoyz's Avatar
Car: 86 Monte Carlo SS
Engine: 5.0 liter High Output w/ TPI
Transmission: built 700R4 Auto
Axle/Gears: 10 bolt 3.73
I just did a TPI swap into my Monte Carlo SS and it does this also. I did not think anything was wrong.
Anybody else?
Old Jul 17, 2006 | 12:00 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its a normal thing to keep the car from stalling. However, that sounds a little much. Try removing the throttle body from the plenum and cleaning the IAC passages by removing the motor and spraying carb cleaner in there to remove the dirt. Then following the IAC reset procedure tech article on this site when you reinstall everything.
Old Jul 17, 2006 | 07:05 AM
LT4Hawk9's Avatar
Engine: 350ci LT4
Axle/Gears: 3.42:1
Cool. Thanks, guys. My brother used to have an 87 Vette, and he didn't remember it doing that...so mine must be worse than it should be. I'll try it and see what happens.
Thanks, again!
Wade787b
Sep 29, 2015 01:15 PM
db057
Sep 4, 2015 07:57 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
wayshegoes
Aug 17, 2015 12:00 PM
NBrehm
Aug 5, 2015 07:57 PM
