studdering at low rpm's
Old Jul 19, 2006 | 02:00 AM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
recently, on my 355 TPI motor, at low rpm's, i can hear and feel the engine studdering every couple of seconds. once i raise the idlle, the studder goes away...... what should i look for to find the problem? kind of seems like the engine is misfiring at low rpm's maybe.
i've checked the plugs, the wires, etc.... i was thinking more along the lines of a fuel problem, but my fuel pressure is perfect 100% of the time, in the 40's
Old Jul 19, 2006 | 04:46 AM
qube's Avatar
Car: 1988 Pontiac GTA
I had this problem, it was more apparent when the engine was hot, turned out to be the coil/dizzy module.
Matthew
Old Jul 19, 2006 | 05:23 PM
bigchief's Avatar
hmm ill check it out, thanks
Old Jul 23, 2006 | 11:06 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
is it while moving? Could be the transmission....converter shutter. Mine does it alittle bit. Check the lock up plug..mine came loose and had a half *** connection...reconnected it and it helped alot but i know my plug and pigtail are both busted anyway so i know that thats my problem.
Old Jul 23, 2006 | 11:59 PM
bigchief's Avatar
hmmm which plug is that?? right on the tranny itself?? like under the car?
Old Jul 24, 2006 | 12:17 AM
Car: 1991 Z28
Engine: SBC
driver side...towards the tailshaft..sits on top of tranny..like right on top the pan..
the tan plug..
Last edited by LoudmouthSS; Jul 24, 2006 at 12:21 AM. Reason: Automerged Doublepost
Old Jul 24, 2006 | 12:55 AM
Mattwolfy's Avatar
Have you checked the setting on your TPS? How bout cleaning your IAC?
Matt
Old Jul 24, 2006 | 02:16 AM
bigchief's Avatar
yeah, i've cleaned the IAC after i got some fuel in the intake due to a bad FPR..... the car wasnt idling very good at ALL but after i cleaned taht and the MAF it idled fine. i dunno about the tps though
Old Jul 24, 2006 | 03:22 AM
Mattwolfy's Avatar
Are your rpm's dropping up and down when it stutters or does it just seem like its missing?
Old Jul 24, 2006 | 03:25 AM
bigchief's Avatar
rpm's arent really doing anything, but i also wanted to know.. b/c this could even be related, my RPM tach has become VERY sperratic..... where does it get the signal from??? is it from the tranny? if so, maybe there is something wrong that is causing both the tach to become sperratic along with the waay the car is running??
Cornholio7979
Sep 20, 2018 02:31 AM
jklein337
Sep 19, 2018 06:23 PM
777Shock777
Oct 29, 2015 04:30 PM
Prodigious
Oct 4, 2015 11:20 PM
Jake_92RS
Aug 17, 2015 09:42 AM
