Change OVER
Old Jul 22, 2006 | 11:08 PM
tyelton's Avatar
Car: pontiac fire bird
Engine: 305Ho
Transmission: 700R
Axle/Gears: 373POIS
Change OVER
I have a 1989 poniac firebird it has a 305 HO with a tbi i was going to a tpi i was need to no what all i will have to change and will it be worth it i have heard it would be a Horse power gane and i have heads off of a 1986 305 HO will the intake bolt up.
Old Jul 23, 2006 | 10:54 AM
Vader's Avatar
https://www.thirdgen.org/tbitotpi
Old Jul 24, 2006 | 01:08 AM
tyelton's Avatar
Engine: 305Ho
Transmission: 700R
Axle/Gears: 373POIS
I tryed to email you and i do not thank it went throw .I HAVE A GEAR DRIVE TIMING SET I HADE TO UNPLUG THE KNOCK SENSOR .WHEN I BUILT THE ENGINE I HADE PUT HEADS OFF OF A 1986 MODEL THE INTAKE WITH THE TBI THAT I HAVE NOW I HADE TO HAVE IT WORKED TO FIT THE CENTER BOLTS WOULD NOT LINE UP WILL I HAVE THIS TROUBLE WITH THE TPI INTAKE .I ALLSO HADE THE FAN WIRED TO COME ON WITH THE IGNITION.THE WIREING HARNESSTHAT I HAVE CAME OFF OF A 1985 TA WILL I HAVE ANY PROBLEMS WITH THAT.
Old Jul 24, 2006 | 11:48 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
there is no 305 H.O TBI. You will need a different fuel pump for sure.
IROCtometal
Sep 20, 2015 11:08 PM
64goatman
Sep 9, 2015 01:09 PM
IROCtometal
Sep 9, 2015 10:01 AM
FormulasOnly
Sep 6, 2015 10:42 AM
luvofjah
Sep 3, 2015 07:08 PM
