will LT1 mass air sensors work on TPI?
Old Jul 27, 2006 | 10:19 PM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
Hello
I know that the LT1s have both MAF and MAP, but could i put a LT1 MAF on my TPI with no problems?
Speed
Old Jul 27, 2006 | 10:39 PM
Vader's Avatar
The stock Bosch MAF on TPIs generates a linear voltage signal between 0 and 5 VDC to indicate the mass of air moving through the sensor. The LT1/4 Delco/Hitachi MAF generates a square-wave modulated frequency signal to indicate air flow through the sensor. Without some sort of external signal conditioning, the ECM won't recognize the signal.
Even if the signal could be translated from a modulated frequency to an analog voltage, the ECM will STILL only be able to interpret a maximum of 255 grams of air per second as a sensor input. The limitation in the system is not the MAF, but the firmware in the ECM (NOT the programming in the PROM or MEMCAL) which digitizes the input signals so the ECM can calculate them.
Old Jul 27, 2006 | 10:46 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
You will need something called a "translator" for it to work properly. They are not directly interchangeable.
Old Jul 28, 2006 | 07:17 AM
Car: 1989 IROC-Z
Engine: 346 LS6
thanks...
Thats all i needed to know.
speed
Old Jul 28, 2006 | 07:45 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
vader, seriously I do not hold nuts often but damn if I was a girl with a maro
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
92purpz28
Aug 11, 2015 02:30 PM
squiggy2
Aug 9, 2015 09:30 PM
