can i get away with stock injectors?
Old Jul 30, 2006 | 07:00 PM
87350IROC's Avatar
Car: 87' IROC
with this combo, can i get away with the stock 22lb injectors?
355
TFS 195's
zz4 or LPE 215 cam
LPE TPI manifold
AS&M runners
700r4
3.27 9 bolt
custom tune
thanks
John
Old Jul 31, 2006 | 09:51 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Yea.. I had TF heads, SR and 219 cam on my 350 and it was ok. I was even using the stock chip with good results.
Old Jul 31, 2006 | 10:48 PM
87350IROC's Avatar
Car: 87' IROC
Interesting, thanks for the info.
Old Aug 2, 2006 | 06:55 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Your 22 #/hr injectors are fine,,, the ECM has sufficient range to correct for what you need while at closed loop mode. However, at WOT, you could be running slightly lean. Install an AFPR and dial in most suitable fuel pressure for your setup. AFPRs are often overlooked as a simple tuning tool.
Old Aug 2, 2006 | 07:38 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
As was said you may need a AFPR if a custom tune can't get enough fuel to the injectors or your duty cycle is to high.
Old Aug 3, 2006 | 08:03 AM
87350IROC's Avatar
Car: 87' IROC
I have an afpr already installed so i'm covered there. Thanks for the help folks, no need wasting money if i don't have to
Old Aug 3, 2006 | 11:20 AM
formul8!!'s Avatar
Car: 2004 GTO
You are better off running a slightly smaller injector at higher pressure for better fuel atomization.
Keep the 22lb injectors and experiment with 48-50lbs of fuel pressure.
Think: thumb and garden hose
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
z28_AJ
Aug 27, 2015 08:59 PM
ezobens
Aug 19, 2015 10:29 PM
