fuel pressure regulator bolts
Old Jul 31, 2006 | 10:37 AM
president89's Avatar
Car: 86 Monte carlo ss
Engine: tpi l98
I noticed the bolts that hold down my fuel pressure regulator look like a torx bit, but with a piece of metal protruding outward in the middle of the bolt. Is there a tool for removing these bolts, or do you chizel that "tit" down and use the torx bit. I'd rather buy the tool than go screwing around and possibly cause myself more aggravation with screwed up bolts.
Old Jul 31, 2006 | 12:06 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
its just a t-10 security bit if i remember correctly
Old Aug 2, 2006 | 09:39 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Yeah, it's just a security screw/bolt, I saw an inexpensive set of matching bits @ my local Harbor Freight last week...
Old Aug 2, 2006 | 10:47 AM
Vader's Avatar
Whichever route you take, apply plenty of penetrating oil and allow it to soak before you even start. Perform a search for "@#$%- FPR Torx screws!" and you'll see why.
Old Aug 3, 2006 | 11:29 PM
WillSpeedy's Avatar
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
be careful you can't get replacement ones anywhere on planet earth.
Old Aug 4, 2006 | 03:10 AM
jethawk's Avatar
Car: 1991 Firebird Formula WS6
Engine: LB9
Axle/Gears: 3.42's
yea i tried the pound the centre down method... after that... only 2 of the 6 screws survived the rest kinda stripped... so im the @#$%- FPR Torx screws boat... i hate Torx
Old Aug 6, 2006 | 07:46 AM
jstoll's Avatar
Car: 91 Formula
I destroyed my bolts too. I just went to the hardware store and bought some stainless steel allen head bolts. only a buck and much better than stock ones.
Old Aug 11, 2006 | 02:50 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
I bought that torx bit, the whole set, at the dollar store. Mine came off pretty easy.
Old Aug 11, 2006 | 04:22 PM
JB22's Avatar
Heed vaders advice. I had one break... not fun to get out.
Old Aug 15, 2006 | 05:09 PM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
Those little s.o.b.s got me too.....
Old Aug 19, 2006 | 01:47 AM
Drew's Avatar
They aren't impossible to replace, they're just difficult to replace. Go ahead and buy the cheap bit, but use it once and throw it away. Otherwise they tend to strip. I modified a bunch of stock fuel pressure regulators to be adjustable several years back. I got into the habit of discarding the OEM screws because they're soft and tend to strip. Replacing them with socket head cap screws is good insurance.
They're a 3.5mm x 20 screw... None of the local hardware stores or industrial suppliers had them, but the hobby industry uses them. If you can't find them on the shelf at a local hobby shop, you can order them from Tower Hobbies.
Great Planes Metric Socket Head Screws 3.5x20mm (4) are zinc alloy plated, $1.89 +shipping for 4. Dubro Socket Head Cap Screw 3.5mmx20 (4) are black oxide finish, higher quality but they're rust quickly $1.49 +shipping for 4.
If they break while removing them, remove the regulator cap, and grab the stub end with a vise grip. Apply mild heat from a propane torch and twist them out. Using anti-seize when reinstalling isn't a bad idea either.
Old May 31, 2023 | 08:15 PM
ponttpi86's Avatar
Re: fuel pressure regulator bolts
Hey i know this is an old ad but i just stepped out a couple of my security torq screws in my FPR and saw that you went to hardware store and bought regular Allen head bolts.
I tried to buy some but they didn't have the size there.Do you know what size bolts go in ?
Old May 31, 2023 | 08:22 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
reread post 11
Old Jun 1, 2023 | 07:48 PM
ponttpi86's Avatar
reread post 11
Ok tried the m3.5 x20 and too long so I found a place online that strictly makes just bolts nuts.
The ones i bought were m3.5 X12m .6 pitch..work great 👍
In case anyone wants to know
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
