Starting and idling problems when cold
Old Aug 1, 2006 | 06:28 PM
silverbullet86's Avatar
Car: 86 trans am
Engine: 305 tpi
Axle/Gears: 3.27 9 bolt posi
I got 86 trans-am with 305 tpi, and after I installed a custom cold air intake it starts hard when cold, has rough idle, and a loud hissing sound from intake. Once the engine warms up it all clear up. I unplugged the maf and it started easier, idle was smooth, and wasn't making the hissing sound. Also in the past month or so I lost 75 miles on a tank of gas. I dont know if the ses light is coming on because it didn't work since I got the car.
Any suggestions?
Old Aug 2, 2006 | 12:30 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Any suggestions?
Go back to the stock intake and see if it runs normal again. MAF's are very sensitive to intakes and if the flow isn't right across the metering portion, or the flow is too turbulent, you wind up with lots of strange problems.
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
perZ
Aug 15, 2015 01:17 PM
killer777
Aug 8, 2015 02:47 PM
