Surging Idle 89 Formula 350
Old Aug 1, 2006 | 11:36 PM
bgmoss's Avatar
Car: 1986 TA t-tops
Hi All,
My 89 Formula 350 TPI is surging when I'm at idle, sometimes almost killing, then overshooting a few times before settling down--then repeats. At higher rpms, it's fine with good accelleration--no noticeable misses.
No fun crossing the border into Canada each day and having the crossing gaurd think I'm getting ready to take off before he's done asking questions.
I replaced the IAC valve, but it didn't make a difference. I have not changed spark plugs for quite a while, so that's my next project. I would like some opinions as to what people think would be the the top most likely causes.
Thanks,
-Brent
Old Aug 2, 2006 | 12:40 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Originally Posted by bgmoss
Hi All,
Thanks,
-Brent
Check TPS voltage
Old Aug 2, 2006 | 02:22 PM
missouraman's Avatar
Car: 1991 trans am
Engine: 5.0l TPI
Transmission: 700 R4 Auto
Axle/Gears: Don't know... DO U!
well i have a 91 t/a with 305 tpi in it. And i just currently went through this problem. I would like to know a little more info on you situation to see if can be of some help. How high is the rpms jumping? In Drive ( if auto ) or neutral ( manual ) 600 is the ideal idle speed. Is it jumping up from 600 and then back down or is it jumping up and then dropping back down past 600? Also i found have realized ( atleast on my car ) if you have your tps set at excatly .54 you have a better response time off a dead stop. Most people and even the chiltons book says between .45 to .60 is good but i would suggest putting it as close to .54 as possible. But if you just replaced your iac and your tps is set right sounds like your computer is jumping in and out of open and closed circuit. But it also could be a faulty o2 sensor. Does it or has it flashed any codes? ( check engine light came on at all ) One givin maybe a little more indept description and a little more info i possibly could be of some assistance
Old Aug 2, 2006 | 08:33 PM
bgmoss's Avatar
Car: 1986 TA t-tops
Hi,
The rpms jump from 650 to ~1200, then back down to ~100, then up again and finally settles back at 650 very quickly While in Drive. If in Park or neutral, the idle jumps around from 650 to ~1200. NO codes are being set that I know of and the Check engine light has never come on. I have not checked the TPS voltage--maybe its been knocked. I will check that first and also scan it for codes.
Thanks,
-Brent
Old Aug 2, 2006 | 08:38 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
When you replaced the IAC, did you clean up inside the trhottle body where the pintle sticks in? It gets REALLY gunked and cruddy in that hole. I used an old toothbrush soaked in carb cleaner to clean mine out. Then spray more TB cleaner in the IAC air passages.
Old Aug 2, 2006 | 08:45 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Have you removed or replaced any other stuff relating to the intake?
Also, a surging idea is usually a sign of a vacuum leak.
Old Aug 3, 2006 | 10:51 AM
formul8!!'s Avatar
Car: 2004 GTO
The other thing is if the car has the original injectors (which I highly doubt).
The OEM "mul-tec" injectors could be the culprit.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
okfoz
Mar 9, 2017 02:35 PM
bamaboy0323
Sep 3, 2015 06:07 AM
jbd1969
Aug 17, 2015 07:06 PM
