TPI with a 383 stroker - What intake is best?
Old Aug 12, 2006 | 01:55 PM
BrianI's Avatar
What intakes are available for a TPI car that would breathe enough for this? Thanks
Old Aug 13, 2006 | 02:20 AM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
52mm tb
TPIS runners and base (extrude honed if possible)
and either AFR 180 or 195cc heads
Old Aug 13, 2006 | 10:07 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
For a 383....the HSR or SuperRam would be best. SuperRam would make more low end.....the HSR more upper end. I went with the 58mm considering is the same price as the 52mm so I can always upgrade the engine and not worry about airflow.
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
86White_T/A305
Aug 17, 2015 12:16 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
