got a problem here..
Old Aug 13, 2006 | 11:21 AM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
So for the past couple of months...not in any specific conditions..the car wont even turn over when i put the key in. I have a feeling its the vats system and that my lock cylinder is bad. And of coarse i was in the staging lanes at the track and it didnt start! (that sucked lol)..that was my biggest fear too. It's wierd, it can go a month without doing it, then do it once etc. I believe its the vats b/c at the track, i believe it took 5 minutes and then she fired up like nothing was wrong. I also realize every now and then, ill sitck the key in and the lock clyinder wont turn...wiggle the key a bit, and it turns fine. I tried two different keys..same results. Now if i order a new lock clyinder from my work (ac delco one) with a new key and put it in...will the car not work?.since its not the right key i guess?..or since i am changing the lock clyinder will everything be fine? Im just worried about the vats and the fact that i am putting in a differnt lock/key combo...i am afraid the car won't recognize it and won't fire. I really should have gotten this crap disabled on the prom..
Old Aug 13, 2006 | 11:30 AM
Car: 1991 Z28
Engine: SBC
o screw changing the lock clyinder..if i can get away with just throwing a resistor on the vats wire...then ill do that..any body have pictures of the wiring that i need to tap?
Old Aug 13, 2006 | 11:46 AM
Vader's Avatar
Did you check the Tech Articles?
https://www.thirdgen.org/vats_passkey_system
Old Aug 13, 2006 | 08:47 PM
Car: 1991 Z28
Engine: SBC
no i did not see that...hmm
ok well how do i test the resistance it my key with a voltmeter...stick positive on one end and neg on the other end of the chip?
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
