finishing the tuneup
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Well my car has new plugs, wires, fuel filter, air filters, o2 sensor, thermostat, water pump, radiator, and fan switch. i have 216 dollars to finish the tune up left. So far ive decided to buy a msd coil and msd cap & rotor with the money. Then change the oil & oil filter (oil was fresh about 5 months ago but it sat since then) pcv valve, iac valve (cleaned the original one set minimal idle but still has a small surge), And finally the tps sensor. Is there anything i should add that i missed?
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
Hows your belt? Tranny filter? Rear end gear oil? I like to check my wheel bearings when I do a major tune up.
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
belts good, tranny fluid and filter are new, but the rear end doesnt even have a gasket it was cyclicone'd who sells a 9 bolt gasket?
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
why are you replacing the TPS? is it malfunctioning? If it is working fine I wouldnt't mess with it. You can adjust the tps too, or at least check for proper adjustment.
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Radiator hoses. Possibly heater core and hoses. Fix AC. Re-torque header bolts. Check tire pressure. Re-balance tires. Get alignment. Set base timing.
AC delco cap and rotor would be better IMO.
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
well im changing the iac because i cleaned it and set the minimal idle and it still has a slight surge. So i figured to might as well change the tps while im at it. Timing has already been set at 10 instead of 6 in advance and the tires are brand new.
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
well this work
if i use this http://www.partsamerica.com/ProductD...rttype=&ptset= rear gear oil do i have to use limited slip additive too?
Axle/Gears: 9-bolt/3.45
Get a distributor cap with brass terminals. I think MSD's has brass, but the ACDelco one prolly doesn't. Hypertech's cap has brass, and their coil is rated as being stronger than MSD, Mallory, Accel or GM. And it's all a perfectly stock fit.
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
i dont need the money anymore i have 100 doller money order to get all my tune up needs
Car: 92 Camaro RS, 04 Dodge RAM
Engine: 305 TPI / Hemi 5.7L
Transmission: 5 speed / 4x4 auto
Hey, for those of us with TPIs, check me on the order for setting up the motors tune...1)verify EGR system is functioning properly
2)set idle speed (IAC controlled "minimum air") to 450rpm
3)base timing to 6 degrees BTC
4)set TPS sensor to .54-.56 volts
Is this correct?
Linson
Sep 21, 2015 01:08 PM
