EGR vacuum suply line?
Old Aug 16, 2006 | 09:47 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Ok, I always answer people's questions so not it's my turn to ask one.
I got a '91 TPI setup. The EGR vacuum supply line runs from the solenoid in the back (under the coil) to the TB. It's connected to a nipple on the bottom of the TB, front driver side. But with the engine running, there is no vaccum in that nipple. :shrug:
I took the TB off and blew into the nipple and air came out of the FRONT of the TB. I'm puzzled.
The EGR valve is controlled by vacuum (and an electric solenoid) so no wonder my computer is thowing 32 (EGR) code when there's no vacuum there.
Can anybody help with some answers, please?
Lou
Old Aug 16, 2006 | 10:10 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
There will be no vacuum at that port during idle. Im not sure why but rasie the rpm to about 1500 to 2000 and feel that port and vacuum will start at that port. Its only drawing a vacuum at part throttle cruise. Go throught the GM code 32 chart I had the same problem and had a bad solenoid.
Old Aug 17, 2006 | 09:06 AM
BigBadLou's Avatar
Engine: TPI
Thank you, I'll test it at higher RPM's.
Lou
Old Aug 24, 2006 | 04:22 AM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
i had the exact problem... i removed the hex screws from the "tuned port" plate. and discoved the small gasket was bad and that the vacume was leaking out and not going down through the nipple. there is a small chamber in there that sends vacume to that nipple. i fixed it with a small bit of forma gasket and bam.. i got vacume you could then replace the gasket. it worked for me. try it
83 Crossfire TA
Jan 3, 2016 01:26 PM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
TBRays98
Sep 6, 2015 05:05 PM
