some 305 to 350 swap Q's
Old Aug 18, 2006 | 10:20 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
hey im changing out the 305 to a 350 in my camaro, and keeping the TPI system, i know im going to need larger injectors, will i need to change the knock sensor and ecm? i havent gotten a clear answer, some say depending on the memcal, how can i tell if its integrated into it, the can is 91z28 SD car btw, thanks a bunch guys
Old Aug 18, 2006 | 05:14 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
YES, on the knock sensor
NO, on the ECM
YES, on the e-prom (chip)
Injectors, yes, 22lb
Thats about all I did, hope this helps.
Old Aug 18, 2006 | 08:19 PM
Car: 91 z28
yep that answers all my questions! thanks guys
Old Aug 19, 2006 | 01:05 AM
Drew's Avatar
Wrong forum, there's an engine swap forum that would have covered this.
At any rate you don't HAVE to change anything. A mild 355 will start up and run fine with the 305 chip, 305 knock sensor, and 19lb injectors. However, if you want the best performance from it you'll want to upgrade the chip, injectors, and knock sensor. Virtually everything else between the two is the same.
Old Aug 19, 2006 | 01:07 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
You have to switch the esc module for a 350 also.
Old Aug 19, 2006 | 10:45 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
305 and 350 starters are different as well!
Old Aug 20, 2006 | 08:14 AM
Todd Chastain's Avatar
Car: 87 iroc z28
Engine: 5.7 TPI
Here's most of what you'll need to change. I know, I had to do it. The knock sensor definately has to be changed. It, thru the ECM, advances and retards the cars timing. The timing will not be correct if you have a 305 knock sensor in a 350. The ECM does not have to be changed !!!, the PROM does. It is programed with all the variables for the 305 that was orgininally in the car. The injectors have to be changed 305s' have 19# injectors and the 350 has 22# injectors. With the 305 injectors in the 350 combined with the 305 knock sensor you run a risk of damaging your new motor! The ESC module will also have to be changed. You can do like the last person suggested and run everything all fu*#ed up or you can fix it right the first time and forget about it. If you have any questions go to "TPIparts.com" they have a link that tells you what you need to do and why.
Old Aug 20, 2006 | 08:19 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Check this link out for some info. 305 TPI to 350 TPI Conversion
Jake_92RS
Jan 28, 2020 10:37 PM
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
