TPI OBDII - Thoughts/Opinions
Old May 4, 2010 | 10:14 PM
  #1001
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Re: TPI OBDII - Thoughts/Opinions
Ahh. Thanks Mike!!. Did not know that. Good info. Thanks Again !
Old May 9, 2010 | 05:43 PM
  #1002
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
question...I recently had my oil changed in my car. Also had the guy pull out my crank sensor and replace the o-ring since it was leaking. Now my car runs rough like it has a constant skip at part throttle, its running way rich according to my wideband, and its WAY down on power.
Is there some certain procedure in dealing with removal/installation of the crank sensor?
Old May 11, 2010 | 03:30 PM
  #1003
S10Wildside's Avatar
No certain procedure. Very straight-forward. Simply pull it out and put it back in.
Old May 11, 2010 | 04:14 PM
  #1004
Car: 89 formula 350
did that. Car still runs like crap. No codes at all. Now I have a turn signal indicator glowing when I get on the gas so im thinking maybe all this is because of a dumb ground issue.
Old Jun 14, 2010 | 10:02 PM
  #1005
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
If anybody needs OBD II parts. I have some for sale in the classifieds.. I'm moving to an LSX motor now.
Old Jun 21, 2010 | 01:19 AM
  #1006
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
thinking about startin my OBD2 swap finally. about how long does it take from start 2 finish on the average?
Old Oct 16, 2010 | 11:18 PM
  #1007
shrEDinsince82's Avatar
Car: 87gta
Engine: tpi 350 f1c
Axle/Gears: 3.08
I have my harness finished but im having problems finding the van file the tuner found one on holden crazy 02 express tried to load it but it was no good any suggestions would be great thanks
Old Oct 16, 2010 | 11:26 PM
  #1008
Car: 87gta
Engine: tpi 350 f1c
Axle/Gears: 3.08
ive been messing with mine for a month.. but this dude took forever to trimm my ballancer i modifyed a 99 truck harness along with the t/c cover and reluctor wheel
Old Oct 17, 2010 | 09:08 AM
  #1009
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I just finished a clean, stock 02 Express and re-flashed my PCM. Shoot me a PM with email link and I'll send it to you.
I took out EGR, VATS, Cannister, Fuel tank and gauge stuff that is needed for 96 up trucks, but not older vehicles.
Ron
Old Oct 17, 2010 | 12:52 PM
  #1010
Car: 87gta
Engine: tpi 350 f1c
Axle/Gears: 3.08
i sent u a pm
Old Oct 17, 2010 | 03:35 PM
  #1011
scuzz's Avatar
Engine: LB9
Axle/Gears: 3.55
i sent u a pm
File sent in TCII format.
Old Oct 17, 2010 | 05:56 PM
  #1012
evilstuie's Avatar
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
hey mate, can i get a copy of the file too plz?
Old Oct 17, 2010 | 07:44 PM
  #1013
scuzz's Avatar
Engine: LB9
Axle/Gears: 3.55
PM me with email link.
Old Nov 15, 2010 | 08:47 PM
  #1014
macertheracer's Avatar
Car: '91 RS CP now is the son's driver
Engine: CP =3.1, will get V-8 maybe someday
Transmission: stock
Axle/Gears: 3.42 posi W/ disks
hey guys: I have just finished my 1997 K1500 to TPI'd 327 conversion, and having a lot of issues with the tune. I think the tuner blew it, it hunts for idle, stalls at stops, backfires, stumbles at cruse, lousy millage.... it goes on and on. I am currently using the stock 1997 Vortec ECM, since I am not planning to turn over 5500r's. But I do have a 411 ECM in my possesion and could use a good tune for the Vortec unit or assistance with the 411. at this point the 411 lis looking best as It may need to go on the dyno to get tuned perfict??? any help would be greatly appreciated The Racer here ar a couple of pictures
http://www.flickr.com/photos/tinbender59/4918222153/
http://www.flickr.com/photos/tinbend...n/photostream/
Old Nov 16, 2010 | 07:14 PM
  #1015
Transmission: stock
S10Wildside: I am willing to pay???
Old Nov 17, 2010 | 05:04 AM
  #1016
Mail order tunes are scary. They are a best guess at proper spark and fuel delivery for your engine combo. I avoid sending mail order tunes because it opens wide the door for rework and bad experiences.
You should identify a tuner who will both drive around town in your truck and make a few dyno pulls while watching the air/fuel with a wideband O2 sensor(s). There are no other shortcuts to getting a well tuned engine/transmission.
Old Nov 17, 2010 | 11:18 AM
  #1017
Transmission: stock
Yes I do understand, BUT I finally have, or rather he contacted me, a gentleman that is going to fix me up with a base tune to get this up and ready for the dyno Smoken!!!!
Old Nov 29, 2010 | 11:31 PM
  #1018
Car: 87gta
Engine: tpi 350 f1c
Axle/Gears: 3.08
you should re pin to the 0411 its not hard and their is a lot more tuners willing to work with that ecm i tryed useing the black box pcm and had no luck what are those injectors from?
Old Nov 30, 2010 | 01:41 AM
  #1019
Transmission: stock
yup, that is exactly where we are going next, it is an easy swap from what I see. pluss I am switching to the LT1 throttle set up so that I can use the updated IAC and TPS
Old Nov 30, 2010 | 11:49 PM
  #1020
Car: 87gta
Engine: tpi 350 f1c
Axle/Gears: 3.08
just buy the adapter from tpis for the lt1 its like 45$ and the tpi tp will work fine
Old Jan 2, 2011 | 05:09 PM
  #1021
evilstuie's Avatar
has anyone got a copy of the express van harness i can use tp start on my conversion they can send me?
Old Jan 3, 2011 | 04:11 PM
  #1022
ch@0s's Avatar
This is way too Kool
Old Jan 3, 2011 | 04:25 PM
  #1023
scuzz's Avatar
Engine: LB9
Axle/Gears: 3.55
I can get you a pinout .pdf of plugs at ecm plugs. If you want that, pm with email address.
As far as complete harness, you should buy a complete from mike@eficonnection.com or pick up one out of 01-02 express from junk yard.
Old Jan 3, 2011 | 05:26 PM
  #1024
evilstuie's Avatar
Hey Thanks for that, I've just PM'd you.
Unfortunately I'm in Australia, no S10's or ExpressVans in sight
I've got 2 tpi harnesses i can use for connectors, a brand new still in box painless harness for tpi, and trying to get my hands on an ls1 harness from a Holden commodore over here. I'm hoping between that and the tpi harness I can build one for a lot cheaper.
I've heard a lot of peopel saying how fantastically difficult it is to make one up from scratch or try re-pinning and adding to an existing harness, but it can't be that hard can it?
If you've got a wiring diagram, the connectors, and a soldering iron, the rest should be easy yeah?
Old Jan 4, 2011 | 04:44 AM
  #1025
http://www.alldatadiy.com has all the service schematics you'll need for under $30.00. If building your own harness, it's a great way to go.
Old Mar 13, 2011 | 05:04 PM
  #1026
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
im selling off all my parts for this swap i have everything and its all new parts but the coil an ls1 pcm i have everything but the map sensor, set-up for an 88 pm me for a price get it cheaper now guys! or i can part it out also
Old Apr 3, 2011 | 10:28 PM
  #1027
xtremeRacer's Avatar
No clue how to pm. Email me with a price: modernClassicsATgmail.
Old Apr 3, 2011 | 11:10 PM
  #1028
Car: 87gta
Engine: tpi 350 f1c
Axle/Gears: 3.08
How much? Thinking about doing another car pm me
Old Apr 5, 2011 | 06:56 AM
  #1029
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
your email didnt work
Old May 14, 2011 | 02:50 PM
  #1030
Car: 89 formula 350
hey guys just a quick question. I need to change the gear ratio on my pcm for some new gears im getting. Is there a handheld programmer I can get to do this? If so what vehicle/application would I need?
Or should I just send it to my tuner?
Old May 16, 2011 | 12:39 AM
  #1031
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Some of the commercial packages can do it. I dont know offhand if any of the hand-helds can. Its not a complicated change, just have to change the VSS pulses per mile, but obviously you have to reflash it. Tuner should have no trouble making the change.
If the PCM just handles the engine, the VSS stuff isnt that critical. Some things will change slightly, but not so much that you need to make changes. If your running an e-trans or TCC, then it needs to be changed.
Old May 16, 2011 | 12:46 AM
  #1032
Car: 88 Camaro SC
Engine: SFI'd 350
On that same topic, I will also be releasing XDFs shortly for the '411 series PCMs so you can tune them with tunerpro. The XDFs for the engine will come first, and if sufficient demand, then the ones for the e-trans. Unlike the commercial guys, I actually have to go into the code to see how things work, so it takes time to get it all together. I have the same leaked info from GM that they do, but the factory comments are vague, and not of much help.
For those interested, the XDFs will probably only cost a small, nominal ammount, mainly just to raise some more money that I can plow back into development. There are about 5-6 XDFs for the engine, and likely another 3-4 for the e-trans and e-throttle when I get them done. Each XDF is pretty big, so there are probably some 2000-3000 parameters that will be editable when Im done. I attached a pic of the engine one just for reference as to what they look like.
OBD reflashing is also in the works...
Attached Thumbnails TPI OBDII - Thoughts/Opinions-fuelxdf.png
Old May 16, 2011 | 07:04 PM
  #1033
scuzz's Avatar
Engine: LB9
Axle/Gears: 3.55
Dimented, I'm glad to see that you've got the ball rolling. It would be nice to crack the complete ecm, and get enough people interested to help make it possible.
Thanks, a million.
I already have unlimited version of Tunercat II, but don't have any datalogging software.
Old May 16, 2011 | 10:53 PM
  #1034
Car: 88 Camaro SC
Engine: SFI'd 350
As far as datalogging, someone wrote a plug-in for tunerpro so OBD tuning could scan using the ELM. I havent tried it out, but TP theoretically can handle sending all the packets. I dont know how well it will work on a slower laptop as you need a complete set of macros for each PID. You have to request them one at a time, and wait for the PCM to respond.
I didnt need scanning with my vortec blackbox as that one has a pretty good and straight forward algo, and is basically a simple one shot deal when it comes to tuning. It will be a must with the '411, though, as it has a lot more parameters, and uses a calibration similar to what would be seen on a MAF only car like a ford. Everything is based off of the cylinder airmass rather than mainly using MAP and baro.
Old May 18, 2011 | 08:43 AM
  #1035
fr3ed0m's Avatar
Car: 92 camaro rs , 72 c10 longbed
Engine: 383
Transmission: 3 on the tree
Axle/Gears: 12 bolt with 3.73 gears/open diff
well i read the first 200 sumthing post and im wondering if anyone has this working with a t56 out of the lt1 camaros? or a tko600 because hurst driveline conversions has a whole swap with everything i need for my truck with the tko trans, and if so what kind of mpgs could i expect?
Old May 18, 2011 | 11:10 PM
  #1036
Car: 88 Camaro SC
Engine: SFI'd 350
I have a TKO in mine. Not too much different than any other setup. There is a lot of stuff in the later PCMs for the manual transmissions, though. They have all sorts of logic to dampen out the engine RPMs. Basically they add or remove spark to try to control the spark advance. They also have decel fuel cut-off during shifts and what not as well. So, having a manual really does impact the tuning side of things, depending on what cal you use.
From my experience, a lot of the spark control stuff can be kind of annoying as it retards teh spark and then adds and removes advance to try to control the engine. Not sure how many tuning packages have it defined, but its definitely a plus to disable it if the cal has it enabled.
As for MPG, that depends on your truck, and what you use it for. The manual will help a little.
Old May 21, 2011 | 07:01 PM
  #1037
Car: 89 formula 350
you guys are speaking German to me! I don't understand tuning stuff, sorry. I guess I will just send the PCM to my tuner and let him change it.
Old May 22, 2011 | 10:42 PM
  #1038
Kaysfirebird's Avatar
hey guys I have a 92 firebird with a TBI 305 and I'm looking to put a 350 TPI out of a 89 IROC. i was wondering if it was possible to use the original TBI wiring harness on the TPI engine?
Old May 23, 2011 | 12:07 PM
  #1039
Harness Layout
TPI sensors, injectors, etc are not located in the same place as a TBI engine.
ECM Compatibility
Since you posted/replied in the TPI OBDII thread, you must have already seen that the point of this thread is the use of an LS1 type PCM. Alltogether different engine control module which will require an alltogether different harness.
Old May 25, 2011 | 10:43 AM
  #1040
Musclemalibu's Avatar
Does anyone know where I can find 1988-1989 Pontiac Firebird TPI Air Duct and Top Loader" air cleaner (actualy container that holds the air filter(1988-1992)? I put a 1986 IROC TPI on a Chevy 400 small block in my 1980 Chevy Malibu. I need to run the Mass Air Flow to the right of my engine compartment and I need these parts to make that work.
Even a part number would help.
Old Jun 10, 2011 | 12:42 PM
  #1041
wyochimneysweep's Avatar
Car: 92 chevy 1/2 4 wheel drive
Engine: 5.0L with TPI
411 swap is just a great addition to the tpi. been running it now for a month and tuning slowly. runs well. mileage is down but slowly getting back into the ball park
Old Aug 17, 2011 | 11:48 PM
  #1042
Car: 87gta
Engine: tpi 350 f1c
Axle/Gears: 3.08
what is the most hp and boost you have ever seen with this conversion single coil seems to like d1sc I just got f1c working on bowtie block 383 do you think 900hp would be possible??? Thanks
Old Dec 20, 2011 | 09:00 PM
  #1043
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Anyone ever think of installing a power steering pressure switch with the 0411? I'm running an 0411 4X setup and am also running a hydroboost setup, and having the little kick at idle to keep the engine speed up would really help.
Problem is I even though I can locate the sensor part number, I dont know the PCM pinouts for the 0411...
Old Dec 25, 2011 | 12:44 PM
  #1044
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
That's a good idea.
I'm running the 0411 on my 99 Tahoe with 1x/4x 383 Vortec. We added the Hydroboost, and boy does that make the difference on braking!
I added it to the T/A as well, nothing like locking up with your big toe.
It'd be nice to have the compensation to help steady things a bit.
-Craig
Old Apr 13, 2012 | 03:56 AM
  #1045
supamaro383's Avatar
Car: 92 RS
Engine: 383 FIRST TPI OBDII DBW
Axle/Gears: 3.73 POSI DISK
I have had this setup over year and still can't get to ideal 100% ......getting very frustrated, just want to drive my car.....today I spent a couple hours tryin to figure out what's going on , I have codes p0300 which is a random misfire , and a p0342 cam sensor low count ...... I believe it has something to do with the cam sensor. I have tryed to install the cam sensor (dummy distributor ) numerous times and seam to have the same results ......also today I used a thermal gun on my header primaries and noticed 4 out of 8 cylinders are about 150 degrees off .... Please help with any ideas or answers .
Old Apr 13, 2012 | 09:54 AM
  #1046
Car: 87gta
Engine: tpi 350 f1c
Axle/Gears: 3.08
I had some problems with miss fires had a vaccum leak and a tight Intake valve
try using a scanner to graph o2 sensors and spray brake clean on the intake and around the injectors
Old Aug 18, 2012 | 01:03 PM
  #1047
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
s10wildside, what would it cost for you to build me a harness for 84 firebird, tpi intake, vortec dzzy and coil and no maf...
thanks,
chris
Old Sep 24, 2012 | 04:42 AM
  #1048
Ryan3834me's Avatar
Car: 88 TA
Engine: 383
Axle/Gears: 2.77
Does the vortec distributor fit a modded Lt1 intake?
I'm looking to swap to LT1 intake and aluminum heads on my L98 383 block. However, OBD II is coming soon.. If I swap cam, I'll be replacing cover with Vortec timing cover! I'm like all smiles!
Old Sep 24, 2012 | 12:05 PM
  #1049
jwscab's Avatar
Engine: Many
Transmission: Quite a few
The vortec distributor fits any standard small block provided there is enough room for the 'crab' wire outlets, ie, something that would only fit a narrow cap, might not fit a vortec distributor. But the shaft housing and gear is all identical(though plastic). If the lt1 intake will fit a standard distributor, then the vortec will fit.
Old Sep 24, 2012 | 06:35 PM
  #1050
scuzz's Avatar
Engine: LB9
Axle/Gears: 3.55
The main thing to look at, is will it fit between fuel rails, and not hit back of plenum.
Look at below link at #29 and #32 which are pics of TPI intake and Ramjet intakes with vortec dist/cap in them.
https://www.thirdgen.org/forums/diy-...ml#post2801225
On the ramjet intake, I had to shorten and modify fuel rails, but TPI worked without any mods.
