Trickflow heads sensor hole size.
Old Aug 19, 2006 | 12:43 PM
87350IROC's Avatar
Car: 87' IROC
Hey guys. I have the TFS-30400006 Trick Flow Kenny Duttweiler Signature Series 23 Degree Aluminum Cylinder Heads. The sensor holes on these heads are bigger than ones on the stock L98 heads. So what do i do? The sensors i have won't fit in the my new heads. Does anyone make bigger sensors?
Thanks,
John
Old Aug 19, 2006 | 12:54 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
For my vette I was able to use my stock 73 vette sensor but not sure if it would be compatible with the 3rd gen gauge
Old Aug 19, 2006 | 01:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Use a pipe bushing.
Old Aug 19, 2006 | 01:07 PM
87350IROC's Avatar
Car: 87' IROC
did your 73 vette have both a temp sensor for the guage and a fan switch?
Old Aug 20, 2006 | 06:52 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Originally Posted by Apeiron
Use a pipe bushing.
3/8" female(the inside threads) to 1/2" male(the outside threads). The threads are tapered, so the fit gets tighter as you thread the bushing into the head and the sensor into the bushing.
The bushing on the right in the pic(below) is from Lowes(Home Depot's is exactly the same). But its taper gets too narrow because the bushing is deep, so a higher-temp switch(thicker than a lower-temp switch) won't fit through it.
The bushing on the left is from Hypertech, and it comes with their 180* switch for trucks. It's different, not as deep, so there's less taper, and the thicker switch fits through it like it should. No extra cost for the bushing either.
Attached Thumbnails Trickflow heads sensor hole size.-firebirdpipebushing.jpg
evilstuie
Jan 9, 2020 08:29 PM
bamaboy0323
Sep 3, 2015 06:07 AM
355tpipickup
Aug 27, 2015 08:13 AM
