iroc will not start please help
Old Aug 27, 2006 | 04:52 PM
white 1's Avatar
Car: 1989 iroc z
Engine: 5.7
Transmission: t 5
i have a 1989 5.7 tpi iroc 50,000 miles i have a no start problem. i have spark to the plugs,fuel pressure to the fuel rail, but no pulse to the injectors i am checking the injectors w/ a noid light any help would be great. thank you
Old Aug 27, 2006 | 05:30 PM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
Transmission: 700 R4
did the computer quit possibly?
Old Aug 27, 2006 | 08:30 PM
white 1's Avatar
Car: 1989 iroc z
Engine: 5.7
Transmission: t 5
i am not sure how to test if computer is bad
Old Aug 27, 2006 | 08:39 PM
crook's Avatar
Car: 1992 firebird
Engine: 350 tpi
is your security light on while cranking could be vats problem if not check to see if you have 12v on the pink and black wire on injector plugs the left bank uses one fuse and right bank uses another under dash inj1 and inj2 if you do then its a signal problem since you do have spark then its not a pickup problem in distributor, could be wiring from ecm to module, module problem power to ecm or lastly ecm problem let us know
john
Old Aug 27, 2006 | 08:44 PM
white 1's Avatar
Car: 1989 iroc z
Engine: 5.7
Transmission: t 5
the security light is not on and it cranks fine ,i do have 12 volts, i also have spark to the plugs,i have also swapped in a new module and nothing. do you think it could possible be loosing a ground.
Frozer!!!
Jan 19, 2024 04:55 PM
Derick15
Sep 17, 2016 05:28 PM
Wade787b
Sep 29, 2015 01:15 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
mustangman65_79
Aug 11, 2015 03:17 PM
