MAF to SD: VSS?
Old Aug 28, 2006 | 02:37 PM
Rod Behring's Avatar
Car: 88 IROC
Engine: L98 HCI
Axle/Gears: 3.27 9 bolt
MAF to SD: VSS?
I'm considering a speed density swap on my 88 IROC. Will the speed sensor used with a cable driven speedo work with the SD ECM? Would I have to change to the later style VSS? I have a 5 speed if it makes a difference.
Old Aug 28, 2006 | 08:17 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
The VSS worked with my conversion. However there is a "box" to check in the code for VSS on the SD ECM tables.
Old Aug 29, 2006 | 08:26 PM
Car: 88 IROC
Engine: L98 HCI
Are you talking about the yellow speed buffer box or something in the PROM? I plan on burning my own chips, however, I'm still reading up on it and have a lot to learn yet. Thanks for your response.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
racereese
Oct 3, 2015 03:46 PM
