how does cts work? diagnostic issue
Old Aug 28, 2006 | 07:57 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
My check engine light is on for my cts. With my laptop, it reads that the cts is recording constantly 150 degrees celsius which is aprox 300 F. No matter if the engine is hot or cold. I unplugged the connector from the sensor to see no different reading on the laptop. Does this sound like a bad cts or a bad wire somewhere? Could I safely ground the plug that plugs into the cts to see if it makes a difference?
Old Aug 28, 2006 | 08:10 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
you have a short in the wiring somewhere.
if it was an open circuit, like when you have it unplugged it would read -40F, as in 40F degrees below 0F.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Jake_92RS
Jan 28, 2020 10:37 PM
TheExaminer
Aug 26, 2015 04:59 PM
Leggman1
Aug 6, 2015 04:15 AM
