high fuel presure
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Is your gauge accurate, or have you verified it with a 2nd gauge? If it's correct it's probably either a bad regulator or a plugged return line. Does the pressure change at idle when you remove the vacuum line to the regulator?
Dialed_In
Aug 20, 2015 01:45 PM
