I NEED HELP IDEL PROB
Car: 95ta
Engine: 350lt1
Transmission: t56
Axle/Gears: 410
i got a 89 iroc z with a 305 tpi i just bought a mass air flow sensor thinkin it was the problem because it was throwing codes... but i was wrong... sometimes it idels high about 15 to 1800 but if you hit the gas real quick it usually idels right back down... i took the throttle body off and cleaned the inside real good... could it be worn out bushings in the throttle body?... any ideas???????????? been rackin my brain for along time on this one so n e help would be good
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
sounds like a worn throttle spring. mine does it too. i just tap the throttle and it comes back down.
84z96L31vortec
Aug 20, 2017 12:16 AM
