No Power! Help me...
Old Sep 12, 2006 | 12:24 AM
Irocz_newbie's Avatar
Car: 89 Iroc Z
Engine: 5.0 TPI LB9
I got an 89 Iroc Z with the 305 tpi, my problem is that I put the car in gear and when u step on the gas, it doesnt go anywhere until about half throttle, car has new pump, injectors, afpr, slp runners, wires, plugs, headers and 3 inch cat back with no cat. idles rough and stalls when i stop, but starts right up again. any help is appreciated. thanks
Old Sep 12, 2006 | 12:55 PM
Vader's Avatar
Is the "Check Engine" light on while the engine is running?
Old Sep 12, 2006 | 08:41 PM
Car: 89 Iroc Z
Engine: 5.0 TPI LB9
The check engine light is Not on, what would cause it to do that?? fuel pressure is a constant 42 at idle. Any Ideas???
Old Sep 12, 2006 | 09:08 PM
Vader's Avatar
Does the TPS voltage move linearly with the throttle opening?
Old Sep 29, 2006 | 10:43 AM
FGER00's Avatar
Sorry to jack the thread but I have the same issue my tps reads 4.9v and drops as I open the throttle. There are 3 wires. I am reading the voltage from the bottom wire. the car has no power untill I hit over 55mph.
Old Nov 7, 2006 | 01:15 AM
marcika's Avatar
Car: 86 IROC
Axle/Gears: 9 bolt Posi 3.45
Hi, I think I have the same problem. I just got my engine rebuilt. I started it today, everything vent good, car started, i adjusted timing. Now if I press down the gas nothing happens it stays running around 900 rpm's. Not sure whats going on.
Thomas
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
