couple of problems
Old Sep 13, 2006 | 06:35 AM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
couple of problems
My car has a rough and surging idle. I set the minimum idle speed and cleaned and adjusted the iac and still surges. When i set the minimum idle i backed the screw so far back it wouldnt touch the throttle and it still wouldnt get below 700rpms turn the screw just so it touches and it idles at 650rpms in drive sometimes and other times surges between 500-750. Also i replaced my starter because my headers heat soaked the old one and replaced the battery and the car voltage gets really low and surges but never dies or fails to start??
Old Sep 13, 2006 | 12:59 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
where is the tps set- it sould be about .54
when the engine is running rough at idle tap the bottom of the MAFS
Cleotiz
Jan 6, 2018 08:56 PM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 9, 2015 01:15 PM
mustangman65_79
Aug 8, 2015 12:07 PM
