K&N owners..>>
Old Sep 16, 2006 | 05:46 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
K&N owners..>>
Which side do you oil your panels? I don't think it matters because the oil penetrates the cotton gauze but thought I'd ask... just in case I'm wrong.
Old Sep 16, 2006 | 09:12 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Oil whichever side is considered the outside. If you use spray oil let it sit 10 minutes. If you use bottle oil then 20 minutes.
Clean from the inside/out and oil from the outside/in.
Old Sep 16, 2006 | 09:18 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Mike's directions effectively duplicate the instructions found on my "filter recharger" kit.
Old Sep 16, 2006 | 09:53 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
I oiled both sides. Made sure it soaked through good
Old Sep 16, 2006 | 10:17 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
For those of us with MAF, oil even more sparingly than they tell you to....
The more oil you throw on there, the less it flows, it plugs up faster, and
works less efficiently. Oil very, very lightly, a little goes a looooong way.
Mike does indeed have it right, BTW....
(I was a K&N dealer way, way back when they first hit teh scene...)
Old Sep 22, 2006 | 07:30 PM
85IrocZ-28's Avatar
Car: 1985 Iroc Z-28
oil bad for MAF
Yep, clean inside out, oil outside in.
I have K&N's, but have heard that the oil can get the MAF oily and that leads to a slight decrease in performance. I have been thinking of cleaning the MAF with some throttle body cleaner to see if it makes a difference. There is a coating on the inside of my intake...Any one else heard of this?
Old Sep 22, 2006 | 08:23 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
yep, thats what ive heard too. i myself oil very sparingly. i went thourgh all that with the oily maf. i guess i learned the hard way
Old Sep 22, 2006 | 10:56 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
K&N Mass Air Flow Sensor Statement
Old Sep 23, 2006 | 12:12 AM
85IrocZ-28's Avatar
Car: 1985 Iroc Z-28
Good article
Great article. I do have some residue on my MAP, so I will clean that off. I wonder where the oil residue would be coming from then. I am a fan of K&N filters. I felt more seat of the pants HP from a K&N in our Grand Cherokee than I did from a high flow muffler.
Old Sep 23, 2006 | 12:37 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
K&N also states that their filter efficiency is as good or better than paper or synthetic media's. I don't buy either for quite a few reasons.
That said, the MAFs that seem to have most of the trouble are NOT the hot wire MAFs. The hot wire MAFs such as (generally) ours on the V8s will burn off the contaminants if the system is working properly.
As for how I re-oiled mine, I didn't, I took it out and threw it in one of my parts piles next to a few other ones.
