injector issue. I'm out of ideas.. Did research, and can't find the answer here.
Old Sep 20, 2006 | 06:58 PM
clarkstoncracke's Avatar
hello. First off, great site. I've spent a couple days here browsing around before I decided to post up. I can't find any answers using the search feature, so here we go.
1989 Corvette Block with Corvette TPI setup.
1991 Camaro ECM.
I had this setup running PERFECT 2 years ago.. I took it out of a CJ-5 jeep, and there she sat.
Well, 2 years has passed, and I put it into a new rock crawler/jeep. It was very well stored, and I cleaned it up all pretty, put on new headers, new oil pan, blah blah..
Anyways, I now have it in my buggy. After doing the wiring, I was all excited, and turned it over.. Nothing.
I am getting 46PSI of fuel to my rail*
I am getting VERY STRONG spark*
I have a very strong optima yellow top delivering 12.7 volts through the crank cycle*
My injectors fire perfect while testing with a noid light. (I tested both banks)*
My injectors ohm out between 16.4-16.8*
I put in a brand new distributor yesterday (I wasn't getting pulses to my ECM during crank cycle to trigger injector pulse)
AND I AM NOT GETTING ANY FUEL INTO THE CYLINDERS!
The thing runs like a champ when fuel is misted into the intake..
I am at a loss for ideas. I've tried alot of different things, including forcing fuel up around 55psi thinking the injectors needed more fuel to start..
Can anyone point me in the right direction?
Old Sep 20, 2006 | 08:01 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
ecm problem...
Old Sep 20, 2006 | 08:07 PM
Originally Posted by roachjuice
ecm problem...
What is the logic behind this? If I have injector pulse, and spark, what wouldn't be operating properly in the ECM?
Old Sep 20, 2006 | 08:13 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
because this is not in a thirdgen, this post will probably be locked or deleted soon.
my bet is the injectors are stuck closed. this happens when they sit un-used for very long.
you will need to trigger them & lightly tap on them with like a 1/2 inch wrench at the same time to get them freed up, replace them, or send them out.
triggering them & then tapping on them will do no good, it must be done at the same time. the best way to do it is to use a tool designed to trigger the injectors one at a time.
Old Sep 21, 2006 | 01:07 PM
Ok, I just went to a junk yard and ripped a ECM out of a 1990 corsica with a 3.1 liter.
For a whopping 10 bucks, I now have a new ECM. Do I just swap the PROM's out to test it?
Old Sep 21, 2006 | 05:37 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Yes, but it won't help. The injectors are getting thier signal as shown by the noid light.
You apparently have a physical problem with the fuel moving. Personally I'd make sure fuel was moving through the rail and that the pressure wasn't dropping immediately upon attempted startup.
Old Sep 21, 2006 | 11:10 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
See your other post for a helpful answer
Old Sep 22, 2006 | 12:22 PM
chevy_toolman's Avatar
Car: 91 Camaro
Engine: 350 tpi
Axle/Gears: crappy 3.08 open rear
Well if I can be of any help I had the exect same problem. My tpi injectors sat for who knows how long with bad gas in them. Long story short injectors had pulse, ohmed out perfectly, but the pintel valve inside the injector was stuck closed. (the injector would not open with the ecm pulse) I have a pulse generator and fuel injector cleaner so i cleaned them out myself and they are as good as new. my suggestion is new injectors of have them cleaned.
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
gta90
Sep 15, 2015 04:00 PM
formula_novice
Aug 18, 2015 08:48 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
