Water & The TPI Throttle Body
Old Sep 26, 2006 | 09:08 AM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
I took my TB off yesterday and cleaned it up really good. I used spray carb cleaner and a toothbrush, then I went to simple green and some water. After about 2 minutes into cleaning with the simple green and water, it occurred to me that there are electrical components on the throttle body!! Did I completely ruin them, or will they be OK after they have dried out?
Old Sep 26, 2006 | 12:21 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
Definately let them dry out completely before applying power to them or they WILL short out. Once dry all you can do is plug and pray. It should be fine though.
Old Sep 26, 2006 | 12:29 PM
gcgarner's Avatar
Thanks. It will be about 5-7 more days until they go back in, so they will have plenty of time to dry.
I also hit them with some compressed air as soon as I realized I was being an idiot. Thanks for the peace of mind!
Old Sep 26, 2006 | 12:49 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
No sweat, LOL, Kinda reminds me of when I was doing some prom burning and left my passenger side window down and it rained on my ECM for 2 straight days. It was fine. Just be sure to dry it ASAP, I would be a tad worried about the IAC windings possibly rusting. Use WD-40, should displace the water as well.
Old Sep 26, 2006 | 01:10 PM
gcgarner's Avatar
Forgot to mention that I shot the whole thing down with WD-40 after it air-dried. Thanks again!
P.S. What are the IAC windings? I thought the IAC was under the plenum near the rear.
Old Sep 26, 2006 | 01:37 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
IAC is Idle Air Control. It's a step motor in the TB that bleeds air off to maintain intake air. It is has a square four wire connector to it below the TPS.
evilstuie
Jan 9, 2020 08:29 PM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
