Too much cam?
Old Oct 7, 2006 | 10:00 AM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
Too much cam?
Looking at a 383 crate. Comes with a .487/.508 lift non-roller with 234/244 duration @.050. Am I a fool to think upgraded TPI will work on this? New base, runners, 52mm TB, etc. I also have a stealth ram. Is this a better choice, or should I just ditch the cam altogether for something with less duration?
Old Oct 7, 2006 | 01:59 PM
brutalform's Avatar
Go Stealth Ram!
Old Oct 7, 2006 | 03:37 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
,with that cam
Old Oct 7, 2006 | 03:39 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
Use the stealth ram, if it hasnt clicked yet lol
Old Oct 7, 2006 | 05:26 PM
Camarosyc427's Avatar
Car: 75 Mercedes 450 SEL
Engine: Chevy 302(building),4.5LSOHC in use
Transmission: mercedes 3 speed auto
Axle/Gears: no clue
go higher with ur compression ratio if u want to use all that cam like 10.5:1, if u look at my post to ur question in the other guys 383 thread it goes more into detail
Old Oct 7, 2006 | 09:37 PM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
Will an LTR setup be completely useless? I only ask because if I run into fitment issues, I'll probably go back to the TPI.
Old Oct 7, 2006 | 10:27 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Yes, that cams power band begins as the tpi begins to run out of breath.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
