car runs like crap at low rpms
Old Oct 10, 2006 | 02:23 AM
Parts4sale's Avatar
i start the car it cranks over about 2 times starts, today the rpms stayed at 2000rpms at start 10sec later then it comes down to its normal idle 900, then does this (loopy cam) shake (rpms go 200 to 1000 up and down) barley staying running, just a hair from dying, rev it sounds normal, 5k revs smooth no back fires nothing, then when you go under 1000 rpms it starts to bounce up and down, today after a 5k rev i bring it back down to 1000rpms let off ran sound fine then stumbles then car shakes hard small heist engine died, before that it would stay running just bounce off the low rpms just about to give up and stop running, what would cause this? i did it the TB wet when i was sanding some of the build up oil deposits on it, i pluged everything in, anyone got an idea?
Old Oct 10, 2006 | 07:27 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
1st thing I would check for is a vaccume leak.
Old Oct 10, 2006 | 07:49 AM
ezysk's Avatar
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
I had the same problem with my 85. It turned out to be the Mass Air Flow Sensor, but I would definately check everything else first, since MAFs are not cheap. Just my 2 cents.
Old Oct 10, 2006 | 08:16 AM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Make sure you plugged the MAF back in securely. Any codes?
Either way - sounds like the MAF is unplugged, the IAC is operating "Well Enough" if the car adjusts idle speed. If the MAF is plugged in securely, I would run the car until you get a code. If you still don't get a code after several minutes (operating tempature reached), I would investigate the following:
Vac leaks
MAF BurnOff relay
EGR Solenoid function
EGR function
But, that's just how I would handle the problem
Old Oct 10, 2006 | 01:37 PM
Parts4sale's Avatar
whould doing the TB bypass cuz a vaccume leak? i forgot to add one thing, when i had the tb off the back of the bores whwere full of a light coat of dry oil depoists, i did run the tb over water well i was whiping that hard oil off, could i maybe have screwed up something on the tb? also is there a way to test the maf? i might try upluging the maf and if it still runs the same should that rule it out as the maf? egr stuff works, i checked everything else wires plugs, its just weird how it wont idle but well stay runnig at higher rpms,
Old Oct 10, 2006 | 01:47 PM
ezysk's Avatar
Sounds so much like my MAF issue I had, but unfortunately I don't have a great way to test this. I just tested everything else in my case, then eventually replaced the MAF.
Old Oct 10, 2006 | 02:27 PM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
That definitely sounds like a vacuum leak, especially if you are getting no MAF code while idling/driving. If it started when you took the TB off and put it back in, I'd get yourself all new gaskets and reinstall it, torquing everything properly.
Old Oct 10, 2006 | 02:36 PM
ezysk's Avatar
Much cheaper to cross of the little things first.
How does the car run when it warms up again?
Does it work better or the same?
Old Oct 10, 2006 | 03:30 PM
Parts4sale's Avatar
heres a video of what its doing, i ran my data loging stuff its so messed up keeps counting knocks and retareds the timing, i have the data logs if anyone wants to see them? im thinknig i fired my pcm,
specialized
Jun 18, 2022 09:26 AM
9192camaro
16
Feb 3, 2019 12:21 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
