stock heads, cam, and intake
Old Oct 13, 2006 | 07:15 AM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Im trying to see if i can get my car into the 13's with stock heads, cam, intake, and gears. I have 2.77 i just want to hear what i should get that i can install myself. I have a 2,000 grand limit. My current mods and drag times are in my signature.
Old Oct 13, 2006 | 07:44 AM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
one thing that would help you out alot would be to put a converter in it. that would drop your 60 ft probably 2 tenths if not more. also learn, or have someone who knows, how to burn your own proms. I havent actually done it with my car yet but there seems to be a lot to be had from it (stay away from off the shelf proms) between those two items you should be in the 13's with only using half of your budget.
Old Oct 13, 2006 | 12:54 PM
Mark 89Formula's Avatar
Agree. Definitely possible with a converter, some sticky tires, and good driving. PROM work would be helpful too. You can do all this within your budget.
Old Oct 13, 2006 | 01:52 PM
Abubaca's Avatar
I agree.
I have a 2400 B&M holeshot and it made a big difference. No times, I don't drag much, but seat of the pants was awesome!
Old Oct 13, 2006 | 03:49 PM
zz4monte's Avatar
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
Converter and slicks might do it.But this like intake would help.
Old Oct 13, 2006 | 04:37 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
i dont know if it would be all that simple. did you spin any off of the line. what was your timing at on that run. i still think with that much money you should get there with some to spare.
Old Oct 13, 2006 | 10:02 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
while your at it box the rear control arm and panhard
Or buy some new stuff
this will help with the twist caused by the slicks and high stall
Old Oct 13, 2006 | 10:17 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
stall, a good tune and suspension mods should do it. i think the gears really are killing you thou. get some 3.23s that will help hugly. if you really dont want the gears than the mods above should do the trick.
Old Oct 14, 2006 | 01:34 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Slicks, and a stall should get you where you want to be; that or nitrous. Don't be afraid to go a little overboard on the stall, say a 3000 lockup. The price is higher but it's worth it especially with the 2.77's. With a 2,000 grand limit though why not just buy a jet
Old Oct 14, 2006 | 02:23 AM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
SPRAY!!!!!!!
Old Oct 14, 2006 | 03:16 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Spray it.
I have changed my cam, but still stock heads and intake.
Best on the g-tech was about 14.1-14.2.
With the nitrous I was about 12.8-12.9.
Old Oct 15, 2006 | 09:37 AM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
lol im afraid of nitrous probaly end up blowing my engine even though its in good shape but it has 111,000 miles. I think a converter is a good idea too im thinking of a vigilante lock up 2800rpm stall. I would do gears but i cant find ones for a 9 bolt that arent like 300+ then theres the installation and a 3 series posi probaly 600 right there not to mention having them installed probaly buy a set of rear iroc wheels to put some mickey thompson drag radials 255/50/r16's. When i do the stall i might get a trans go shift kit from 700r4/4l60.com and a cooler and new pan. As for suspension goes i was looking into boxed lower control arms from bmr and umi lower control arm relocation brackets. So with shift kit, converter, drag radials, lcarbs and lca i think i could hit 13's pretty easy. Just last night i pulled up to a 2001-2004 mustang gt and beat him by a car from a 30 mile roll. And raced my friends hemi truck with 3.92 gears gave me hell from 30-60mph at my door then when 60 hit the hemi was done.
Old Oct 15, 2006 | 02:49 PM
I'de stay with your 2.77's and go up a little on the stall, maybe 3200, if you're getting a Vigalante the price is set so you can get whatever stall you want in it. The shift kit and cooler will compliment the stall very well. If you're not getting wheel hop now you will once the stall goes in so the LCA's and brackets is also right in line with what you'll need. I got my car into the 13's and now I'm shooting for mid 13's. Next round of mods includes my ported base, LS1 injectors, and new prom. Good luck on the build, it looks like you're definetly headed in the right direction.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Mar 5, 2017 06:37 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
camaro71633
Sep 1, 2015 10:24 AM
