brake and rpm
brake and rpm
anyone notice an rpm drop when the brake is pressed? i dont know if it is normal. when in neutra... i can press the brake pedal and the rpm drop by like 200.
Also, sometime my rpm are at 500 and NOT in drive. In drive it is always at 450 - 500 rpm.
Vaccum leak?
Vaccum leak?
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
If you're driving and the rpm drops when the brake pedal is pressed, that is because the torque converter clutch (TCC) is unlocking, which is normal. The park/neutral idle speed is 50-100 rpm higher than the drive idle speed as programmed in the chip.
Street Lethal
Apr 30, 2019 12:14 PM
Dialed_In
Aug 20, 2015 01:45 PM
