cruise control?
Old Oct 15, 2006 | 11:07 AM
sweet_87_iroc's Avatar
Car: 1987 Iroc-z camaro
Engine: 5.7 Liter
cruise control?
There are two vacuum lines that are on top of the cruise control where do they go from the cruise control...........I took my camaro apart and those are the only two lines I can't seem to figure out please help........(pic would be useful)! Thanks
Old Oct 18, 2006 | 05:34 PM
MiTHRiL's Avatar
Car: 93 TA, 92 GTA, 91 TA
Engine: LT1, L98
Transmission: T-56, 700R4
Axle/Gears: 3:23
The smaller vacuum line (5/32" i beleive) goes to the T connector nearby, which goes to the vacuum reserve and to the passenger side of the engine around the EGR / sensor behind the runners.
The larger vacuum line is for the brakes and that line runes on the driver's side of the engine (under master cylinder) and goes into the firewall.
hope that helps. if you're still unsure i could snap some pix for ya
Old Oct 19, 2006 | 01:00 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
To add on to that the one that goes into the firewall connects to your brake switch or a simple valve that opens when you push in your pedals. Like he said, larger one goes to the firewall and smaller one goes to the T of the vacuum reserve.
Old Oct 19, 2006 | 06:24 PM
Engine: 5.7 Liter
ok.....when you look at the t connector you have the line that goes to the cruise control and one that goes towards the firewall what about the other vacuum line in that T connector where does that go?
Old Oct 19, 2006 | 07:15 PM
MiTHRiL's Avatar
Engine: LT1, L98
Axle/Gears: 3:23
Vacuum reserve 'orb' which is right in front of the drivers side tire. You can see it if you look from underneath the car
junior419
Apr 7, 2025 11:35 AM
wigmobile
Feb 26, 2025 02:56 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
scottmoyer
Sep 7, 2015 07:06 PM
