Check engine Light and Fans ON!!!!!!
Old Oct 16, 2006 | 11:48 PM
Striker27's Avatar
Car: 1986 305 IROC Z
Engine: 305 tpi
Well it has been a few months since I attempted to drive my 86 IROC. I went to start it and right away the fans came on as well as the check engine light. When the car started up it felt like it was goona die as soon as I hit the gas. It will idle not very well but it does idle. I am stumped here. I tried to do the paper clip test with the 5 and 6 pins jumped. With this all I got was a constant on check engine light no codes or nothing. The car is basically undriveable as it sits right now and I have no idea what way to turn. Any help would be greatly appreciated guys.
THANX
Old Oct 17, 2006 | 12:08 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
sounds like a bad ecm / prom calpak.
Old Oct 17, 2006 | 01:03 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
It's in Limp Home Mode. There is something wrong with the ECM or PROM.
Old Oct 17, 2006 | 01:17 AM
Striker27's Avatar
Engine: 305 tpi
Since it is starting to look like my computer is it possible to use the computer out of an 1988 tpi LB9 camaro..
Would their be any problems if I were to do this????
THANX
Old Oct 17, 2006 | 02:53 PM
Car: 1988 IROC-Z
the same 1227165 ecm is used from 86'-89'. you are good to go. use it and see what happens.
Old Oct 18, 2006 | 08:04 PM
Striker27's Avatar
Engine: 305 tpi
Well I changed out computers and it has not run this good in almost a decade.
THANX
This board is well worth it!!!!
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
