1990 TPI iron 305 heads vs L98/ZZ4 aluminums
Old Oct 22, 2006 | 02:43 AM
MedVader's Avatar
Car: 90 Formula hardtop
Engine: 5.0 TPI
OK I don't want to go through the trouble and expense of pulling heads to swap out for something that does exactly the same thing.
CC - same? 58cc?
intake port volume - same? 163cc?
exhaust port volume - same?
chamber shape same?
valve sizes Intake - 1.94 vs 1.84? Exhaust valve same? 1.50?
chamber shape same?
Old Oct 22, 2006 | 10:54 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
The 305=1.84 valve
L98 alum=1.94
both are 58cc
Alum is about 22lbs lighter /head
The L98 alum are superior, just they are more $
Old Oct 22, 2006 | 04:42 PM
MedVader's Avatar
Engine: 5.0 TPI
Originally Posted by LB9GTA
The 305=1.84 valve
L98 alum=1.94
both are 58cc
So other than intake valve size and weight, they're identical?
port shape? combustion chamber shape?
If that's it, it ain't worth swapping out heads.
Old Oct 22, 2006 | 06:46 PM
Damon's Avatar
The aluminum heads also don't have an exhaust crossover so your EGR system won't work AND the aluminum heads use the earlier style intake bolt pattern.
I have heard several people report that the ZZ4 versions of those heads have significant port/valve/valve seat improvements over the original assembly line corvette L-98 heads.
Old Oct 22, 2006 | 10:15 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
I was going to swap in the L98 alum in my 305 and I was hoping for about 30hp and 45lbs off the front end.
IMO, it's worth it for a 305, for anything bigger in cubic inches, not worth it.
Old Oct 23, 2006 | 08:09 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
https://www.thirdgen.org/forums/tbi/...-headflow.html
Old Oct 23, 2006 | 12:13 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
I think my numbers in my sig speak for them selves. I have a bone stock bottom end 305 with these heads, a mild cam, and ported stock intake parts with a bone stock chip. In my opinion these heads are the ideal setup for a 305.
Frozer!!!
Jan 19, 2024 04:55 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
marcusaw
Aug 10, 2015 08:13 AM
