Lopey camshaft?
Old Oct 25, 2006 | 06:44 PM
downtoearth's Avatar
Lopey camshaft?
Alrighty, Ima go ahead and admitt it. I know nothing of picking out a cam for a computer controlled vehicle. All I am after is the sound, maybe a single pattern, low lobe seperation, below .500 lift. Let me know what you think. I ran a crane 274 energizer in the carbed engine but I have know idea if it will work with the TPI, I love the way she sounds though!
Yeah I used the search, lol.
350
AFR heads
10.1 comp
speed density TPI
Old Oct 26, 2006 | 09:44 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
I used whats in my Signature, It sounds really good! Heres a pic of my motor also:
Old Oct 27, 2006 | 01:06 AM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
well tenpin.....you and I have MAF and he is dealing with SD....while that is cool, you need to know prom tuning. I don't know, maybe you know your stuff, but SD is alot more sincitive to that kind of change... your talking about a radical change in engine vacuum and fueling demands...
i have the cc306... pretty darn big (not huge) 230 244 @.050 on a 112
it sounds lopey at 1000 idle
and down right choppy at 650-750 in gear
I had to totally stupifiy my O2 sensor
swing points down to like .250 volts
just to get it to stop smelling like a gas station...lol
Old Oct 27, 2006 | 03:03 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
If you stay under 500 lift, under 220 duration and 112+ LSA there's a chance the cam will agree with your PCM tuning with some increased fuel pressure. I did a 110 LSA cam with a TBI on top years back before I knew much and it would run great until the 02 sensor came online then it would die repeatedly, it was a horrible experience I tell you now. It would be beneficial all around to get into prom tuning, but you can get away with a little on what you have. I'm sure some of the members on here will chime in and tell you what you can and can't get away with. You may want to post in the prom tuning board and see if you get any responses there. Good luck on the build.
Old Oct 27, 2006 | 05:12 PM
formul8!!'s Avatar
Car: 2004 GTO
TPI's do not like really lopey cams. Messes up the resononace of the runner tuning and kills your airflow on the low end.
Old Oct 27, 2006 | 07:54 PM
Ackattack's Avatar
Car: 99 Corvette/72 GMC
Engine: LS1/L98
Transmission: M6/700R4
Axle/Gears: 3.42/3.73
I'm looking at cams bigger than the CC 306 But of course I'm not planning on using the TPI intake either, just the block and computer pretty much....so I guess it won't really be TPI anymore. However, I will have to deal with tuning.
Old Oct 28, 2006 | 01:33 PM
Well I plan on sending the Prom to Street & Performance and have then do the tuning for me so I am not worried about that at all. Thanks for the replys I will keep looking around.
CraneCams
Theres the cam I have and would like to use. Its a single pattern, 218 duration, .450" lift, and if I remember correctly 110 LSA. What do you think, think she will be alright cause the cam sounds so badass I dont wanna have to trash it!
Old Oct 29, 2006 | 02:19 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
If you have SD TPI (1990-1992) you need a hydraulic roller cam. That cam is a flat tappet and won't work with your setup.
Old Oct 29, 2006 | 12:44 PM
Block is a '76 4 bolt main block, with a SD TPI up top. Engine was origionally my carbed drag race engine, but now im going to put it in my show truck. So I'm looking to keep it flat tappet for budget reasons. Thanks though.
Old Oct 31, 2006 | 03:35 PM
ROCITUP's Avatar
wont flat tappets mess with the knock sensor?????..............
Old Nov 1, 2006 | 12:28 PM
They shouldn't...TBI engines are flat tappet.
Old Nov 1, 2006 | 03:24 PM
ROCITUP's Avatar
i thought tbi motors were roller also as long as 87 and up icould be wrong so will someone straighten me out if so........later.....................
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
