couple of problems here..
Old Nov 5, 2006 | 05:35 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
Just bought myself another camaro..its an 1988 iroc z with this engine..
383 Chevy Small Block 350 Horsepower Corvette Engine
kid was having interior electrical problems and i picked it up for 1k
I had it started for about 10 seconds..then she stalled and now shell just keep cranking but won't fire. Im not getting spark from the coil wire. I changed the coil and wire that leads to the dizzy..nothing. I tested the ignition module at my work, came up good ( not the most accurate test though, so this may be the culprit).
And this vac line i found just hanging around..On my speed density (92 z28 350) it leads to a three way junction by my map sensor..im not sure bout this car.. Here is where the line begins..
it wrapped around the intake but i dont see anywhere for it to go..
Old Nov 6, 2006 | 02:00 PM
jack harrison's Avatar
Car: 1987 pontiac trans-am
Engine: 350 tpi
Axle/Gears: 3;73 with eaton lsd
that line looks to me to be for your heater. im only guessing here but on mine it is connected to a largeish ball just behind the front bumber. again i may be wrong but i just thought it may help out a little. hope you get it sorted.
Old Nov 6, 2006 | 02:19 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
That line wraps around by the intake to a check valve along with the hvac hose. then the check valve follows a short fe winch line into one of the 2 holes on the plenum.
Old Nov 6, 2006 | 08:54 PM
Car: 1991 Z28
Engine: SBC
ok so it is the same as my 92....i guess it was cut off or something and they replaced the check valve with a straight plastic connector..
Cleotiz
Jan 6, 2018 08:56 PM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 9, 2015 01:15 PM
mustangman65_79
Aug 8, 2015 12:07 PM
