best intake manifold?
Car: 91 Z28 350tpi
Engine: 350tpi starting point
Axle/Gears: stock
i'm in the process of hotting up my 350tpi motor, I've got a ported plenum & slp runners but dont know which manifold to go with, any suggestions?
Also thinking of getting a monoblade as&m tb but will this be wasted on stock heads?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
They're all made by Edelbrock now, and Edelbrock is the cheapest, so get that one.
The stock 48mm throttle body is fine until you get a bigger cam and heads, then get a 52mm one.
Car: 91 Z28 350tpi
Axle/Gears: stock
thanks for advice, what cam will give more good gains but still remain usable & refined?
when i say good gains i know a compromise will be needed so good gains over stock but still useable is what i mean, cheers.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
