High idle and IAC
Old Nov 22, 2006 | 10:47 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
High idle and IAC
I followed the IAC adjustment tech article and did what it said. The idle on my engine is way too high even after doing the IAC procedure. The procedure didnot make a bit of difference. I cleaned the IAC per the tech article prior to the adjustment. I searched the forum and didnot find what I was looking for as to help. Any suggestions as to what the problem is? Thanks, Badman
Old Nov 22, 2006 | 10:17 PM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
I have the same problem I wondering where to start myself. i need some hepl too...
Old Nov 23, 2006 | 01:43 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Was it high before/after or both.
Did u do the reset procedure on warmed up car?
Did you have other issues or codes before attemping this?
Did you clean the entire TB out?
later
Jeremy
Old Nov 23, 2006 | 09:43 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Found the IAC valve was not extending out properly. If it does'nt seat all the way down in the IAC manifold it allows too much air to flow through the idle circut, hence high idle. Clean it out per Vaders tech article and then do the adjustment procedure. It should idle high then come down slowly as it adjusts while running. If not, it may be sticking or just not working at all. Badman
specialized
Jun 18, 2022 09:26 AM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
