adjusting timing
Old Nov 23, 2006 | 10:52 AM
TunedPortTerror's Avatar
Car: 89 Fromula
adjusting timing
i'm trying to set the timing on my 89 formula 350, and cannot find the tan and black wire to disconnect. i have read the tech article, and still can't find it? can someone please point me in the right direction.
Old Nov 23, 2006 | 11:01 AM
92IrocRS's Avatar
Car: '92 RS ~ '92 Ranger
Engine: 305 TPI ~ 2.3 OHC
Transmission: 700R4 ~ Mazda 5-Speed
Axle/Gears: 10-bolt 3.23's ~ 7.5
Its on the passenger's side, upper portion behind the dash. It's a small single-pronged connector. Dissconnect, set, reconnect... good luck man
Old Nov 23, 2006 | 11:05 AM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
the tan wire is a single connector coming from a wire harness, passenger side engine compartment, along the fire wall usually next to the heater/ac blower.
Old Nov 23, 2006 | 11:58 AM
Car: 89 Fromula
Thanks alot for the help guys!! Happy Thanksgiving!
Old Nov 23, 2006 | 01:16 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Last edited by IROCThe5.7L; Nov 23, 2006 at 01:17 PM. Reason: doh pic didnt attach
Old Nov 23, 2006 | 06:50 PM
Car: 89 Fromula
found it!!!!!!!!!!!!! thanks for the help guys!
Old Nov 23, 2006 | 06:52 PM
91stroker's Avatar
Car: 1991 Z28
Engine: GMPP 383 w/AFR's 750 vac.
Transmission: 4L60
Axle/Gears: 9 bolt 3.70
well on a camaro it is on the passengers side in front of the heater box, next to the shock tower..> good luck!
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 21, 2015 07:20 PM
86White_T/A305
Aug 17, 2015 12:16 AM
