intake plentum question.
Old Nov 25, 2006 | 07:13 PM
aperfectcircle's Avatar
Car: 91 Camaro
Transmission: 700 r4
Axle/Gears: stock, soon to change.
hi i recently, traded my 91 rs camaro v6 for a 84 z28 TPI..and there is a connector that goes upwards underneath the plentum that is un plugged.. it is near the distributor does anyone know what this is? the car runs really rough..could this be the problem?? thanks for your help
Old Nov 25, 2006 | 08:31 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
if you have a 84 with TPI, it was added to the car. TPI came out for thirdgens in 85. the 84s had crossfire injection.
if you do have TPI, does it have a MAF or is it a speed density system?
speed density has the air temp sensor on the bottom of the plenum back near the distributor.
i think the MAF cars had the air temp sensor in the MAF sensor, but i could be wrong on that.
Old Nov 25, 2006 | 08:41 PM
Car: 91 Camaro
now that you mention it he did say it was added. im not sure if it is MAF or speed density, im pretty sure it has the mass air flow sensor on the butterfly part of the intake. im not quite sure how to tell, i just got the car like 5 hours ago. thanks for the help.
Old Nov 25, 2006 | 11:36 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
if you have a MAF, it will look like the pix i posted. if you dont see the sensor like this one it is SD. either way the plug your talking about is the air temp sencor. it needs to be pluged in.
Attached Thumbnails intake plentum question.-maf2.jpg   intake plentum question.-maf.jpg
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
Maf for sure have the air temp senser under the plenum, I'm not familar with speed density though. Also have you scanned for codes yet it may tell you the problem.
Old Nov 25, 2006 | 11:46 PM
Car: 91 Camaro
yes thirdgenz it does have the maf where your pictures indicate. would my check engine light come on with this problem?? im not sure if it would go on with this non original motor..maybe? would that sensor cause it to run crappy? thanks for all your guys help!!
Old Nov 25, 2006 | 11:51 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
i would think that it would give you a code. if he put the motor in than he put the tpi computer in, so yea you need it. does it run good now?
of course if he didnt wire it right you might not get a code.
Old Nov 25, 2006 | 11:55 PM
Car: 91 Camaro
no it runs like crap, it doesent seem to be running on all cyls. he said the motor is new and all the computer for the TPI was new. before i checkd anything the timing seems right but i could be wrong, 2 of the spark plug wires were wrong that helped a little but not much. it bearly stays running, im not sure if it was the connector not plugged in, but it is a pain in the butt to try and plug in. like i said i just got the car today and im tryin to work out the bugs.
Old Nov 26, 2006 | 12:01 AM
Car: 1988 IROC-Z28
Usually if theres a code the engine light will come on, but not always. Being that this person put the engine in I would call him with a list of questions to find out as much as you can about your new ride.
Old Nov 26, 2006 | 12:03 AM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
well sounds like thats just one of your problems. one step at a time.
you deffently need to get it on the right timing though. after that just ask and we will try to answer.
ChristinaMarie
Sep 11, 2015 06:28 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
Ironhead38
Sep 7, 2015 02:26 PM
TheExaminer
Sep 6, 2015 11:40 PM
Ian Irvine
Sep 4, 2015 08:08 AM
