Serp to V-belt???
Old Nov 29, 2006 | 04:03 PM
airbrushguy's Avatar
Serp to V-belt???
I have an '88 or '89 350 TPI that has serpentine setup but the car I'm putting it into cannot handle the width of the stock bracket setup. So I'm changing to a v-belt pulley and bracket setup with a Sanden AC compressor and no airpump. Is the water the wrong rotation and if so, what year should I get one for? What else needs to be changed?
Old Nov 29, 2006 | 04:44 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
You will need an alternator, a steering pump, not sure if the serp one will cross over, and a water pump from an 86 or earlier and all the brackets.
Try and find parts from a passenger car, stay away from truck motors some of the brackets and maybe the water pumps are different.
Old Nov 29, 2006 | 04:46 PM
carguy502's Avatar
Car: 1969 Nova
Engine: LT4 Hot Cam L98
Axle/Gears: 3.42 8.5" 10 bolt
If you are converting to v belt, chances are that you will need a standard rotation WP. Check for 85-86 v8 water pumps and I would upgrade to aluminium is you have the scratch for that. Double check the years, but I think most all Chevys used standard rotation long water pumps through 86. Good luck and what are you doing with the brackets?
Old Nov 29, 2006 | 04:58 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
87s also used a serp/v-belt combo, it is possible to check the rotation for those, the standard will have the grooves, reverse rotation will have a smooth surface. Just make sure your brackets will accomodate the accessories that you are using. Personally I would stay serp.
Old Nov 29, 2006 | 06:47 PM
Guest
Guest
Posts: n/a
If youre running Sanden AC, might be easier (although not cheaper) to go with an aftermarket bracket setup.
2012sergen11
Oct 13, 2015 07:38 PM
MantyZ28
23
Sep 29, 2015 11:33 AM
evilstuie
Sep 24, 2015 02:31 AM
MrDano
Nov 22, 2000 09:49 AM
MrDano
Nov 20, 2000 09:19 PM
